a1 technologies studs vs arp studs
Old Dec 28, 2010 | 11:39 PM
bulldog77's Avatar
Default a1 technologies studs vs arp studs
I have been reading on some other forums the difference on the two different studs. I have searched on here and cant find anything on the difference between the two. I am leaning towards the a1 studs cause you dont have to machine the pedstals down, just grind some of the webbing out of the valve cover. I also read that the a1 studs were designed by haisley machine with a1 for the 12vs. As for arps, i guess you have to machine the pedastls down cause you dont get enough of the stud sticking out of the nut. Would like to here some opinions on either one here. Which one is better?
Old Jan 23, 2011 | 10:37 AM
Rodburner07's Avatar
I hve and only run A1s every place i hve known arp is just buying the name and from fellow puller friends they only trust a1s, i hve the higher tensile strenth A1s not the 400$ set i think mine were around 700-800 or so if i remember right, just watch what you buy
Old Jan 23, 2011 | 11:52 AM
seandonato73's Avatar
i have two 12v engines one with arp and on with A1 studs other then the A1's being an easyer install the both seem to be holding up the same
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Whitereaper12v
Feb 28, 2015 11:20 PM
DPRacing805
For Sale
Nov 15, 2014 12:47 AM
7.3dieselMike
Oct 28, 2014 01:46 PM
