Turbo
Old Dec 28, 2010 | 10:03 PM
cummins270's Avatar
Default Turbo
I have a 5.9 cummins 99 and I"m getting 100 horse injectors and have an edge juice with hot unlocker and was wondering whats the best turbo to get??
Old Dec 28, 2010 | 10:05 PM
cummins freak's Avatar
buy mine it will be =laggy at first but you can really grow into it
Old Dec 28, 2010 | 10:09 PM
cummins270's Avatar
Default turbo
Well I was lookin at a 62/14 because ive heard the 64 was to big. how much boost does it build?
Old Dec 28, 2010 | 10:10 PM
I believe its gated at 48psi
to bo honest youd be happer with a 62MM it would be more driveable and you could send it offto ED later to have it opened up if ya want. I'd buy a 62 if i were you
Old Dec 28, 2010 | 10:19 PM
connermcpherson's Avatar
62 is more street able with the amount of fuel your going to be pushing. i run a 66/14 but i push a **** ton of fuel so im able to run a bigger charger. so 62 or 64 at the most
Old Dec 28, 2010 | 10:46 PM
cummins270's Avatar
Im lookin at the industrial inj. silver series 62/14 is this a good choice?
Old Dec 28, 2010 | 10:56 PM
banditsdiesel's Avatar
the bd super b would be perfect for that setup. i used to run that exact setup and it would spool fast run really low egts, and made good power. a 62 would be the biggest i would go unless you are planning on going a lot bigger on injectors and multiple fuel upgrades. 64 and 66mm turbos have been known to "surge" which can make them difficult on the street. smaller wheel= spool faster, a larger turbo will take forever to spool. i had a 66 on the truck with 100hp sticks before i went to 200hp and it was really hard to keep in boost and get spooled up. keep in mind over 45psi of boost you need head studs.
yes, brady really knows what hes doing every thing on my engine is from them, twins, injectors, lines, injection pump, ect.
Last edited by banditsdiesel; Dec 28, 2010 at 10:56 PM. Reason: Automerged Doublepost
Old Dec 28, 2010 | 11:05 PM
cummins270's Avatar
How much boost did your 62 run?
Old Dec 28, 2010 | 11:24 PM
never ran a 62... the bd is a modified 57mm. and with wastegate adjustments you can get as much boost out of a turbo as you have fuel and air flow for. i was able to get 52-55 out of it. also used that same turbo in my first twin set and made 70+ psi with it.
bd makes two versions of the super B. the regular super B is a modified 57mm, the super B special is a 62mm, if im not mistaken.
Old Dec 28, 2010 | 11:36 PM
cummins270's Avatar
Well how does the industrial and the bd compare iis one any better?
