2000 cummins
Old Dec 28, 2010 | 12:54 PM
shorty2tall's Avatar
Default 2000 cummins
2000 cummins Truck was working fine tell high pressure washed the engine after that the truck starts but it wont accelerate it idles rough. what could that be its on CL and it looks decent other then the issue.
Old Dec 28, 2010 | 01:02 PM
RAW's Avatar
RAW
Water in connections at the APPS would be the first place I would look. Any codes?
Old Dec 28, 2010 | 01:13 PM
not that i know of i haven't talked to the owner yet i just thought id ask here first before i talked to him to see if it would be worth it to get.
Old Dec 28, 2010 | 02:44 PM
RAW's Avatar
RAW
I think its always worth it to have a code reader handy. It can make diagnosing much easier. I'd still look at the APPS connector to see if there is water in it, or if a wire came loose.
Old Dec 28, 2010 | 03:21 PM
ok what is that and where is it?
Old Dec 28, 2010 | 04:27 PM
RAW's Avatar
RAW
It is the Accelerator Pedal Position Sensor, and it is under a black cover located at the front left corner of the engine right on top. Underneath it is a 6 pin connector, have a look at it and its wires. It would also be a good idea to remove the black cover and make sure there is no water under there. Also check your fuses under the hood, they are on the left fender.
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
gator515
Jan 14, 2015 01:56 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
mule97
Oct 5, 2014 09:54 AM
