vulcan draw straw what is it how does it help
Old Dec 28, 2010 | 12:44 PM
dodge bomber's Avatar
Default vulcan draw straw what is it how does it help
i was up grading my fuel system so i was going to go with a air dog2 150 pump then i seen this volcan draw straw do i need this? how will it benafit me if i get it?
Old Dec 28, 2010 | 12:49 PM
Farmboy 2.0's Avatar
The Airdogs come with a new 1/2in all metal draw straw with the quick connect fitting already on it. So everything you need for installing the air dog is included
RAW's Avatar
RAW
Depends if you have a intank pump or not. I did, and used the Vulcan DSV (5), and it works really well. All the fuel, both from the engine fuel system and from my FASS, return into the fuel basket keeping it full. I no longer have. 1/4 tank issue as I did with a DS1, which was just a stainless tube that went to the bottom of the tank. If you don't have an intank pump you should be OK to make your connections to the top of the tank and be done.
Old Dec 28, 2010 | 12:55 PM
kyle davis's Avatar
how do you know if you have an in tank pump unless u drop the tank and look?
Old Dec 28, 2010 | 12:59 PM
RAW's Avatar
RAW
If it isn't on the block or frame rail, then its in the tank. Turning the key on and bumping that started will make it run for 20 seconds or so, in that time period you can listen for it.
Old Dec 28, 2010 | 09:35 PM
alwazjeepin98's Avatar
if i have an intank pump u dont need a draw straw or to drill anything
Old Dec 29, 2010 | 09:18 AM
24valver112's Avatar
it also lets you use up all the fuel in the tank i believe. the stock unit sometimes doesnt suck up the last quarter tank. so if your a "light rider" then i suggest it for you
Old Dec 29, 2010 | 11:31 AM
RAW's Avatar
RAW
I can run mine past the empty mark on the gauge. I've put 120 liters in, but I was a little nervous at how low it was. Still, no hickups or anything, fuel pressure held solid. 120 liters is 31.7 US gallons, FYI.
Old Dec 29, 2010 | 11:52 AM
"Tank should not be run below approx. 1/8-1/4 due to sloshing in the unbaffled tank."
From the Vulcan site. I have run my tank really really low too. Its just not a good idea
Old Jan 5, 2011 | 09:35 PM
dam i get 19 gallons and that runs my truck out of fuel its deffinly not getting all it should haha i just put a new in tank pump unit and now my gauge is messed up. i filled it and calculated the miles 16.7mpg ablout 200miles and it gets really close to running out got too do somthing just dont want to drop the tank again
