Guess my numbers
Old Dec 28, 2010 | 07:14 AM
jeffandjess4806's Avatar
Default Guess my numbers
1992 D250
Started with 180HP
Pumped tweaked
Denny T fuel pin
3200 spring
Big open air cleaner
removed muffler from stock system...
Plan on going 4" straight pipe soon
Timing bump 1/8"
What kind of number is you guess?
I will have update after done with numbers and vid
Also what Turbo should l lget? I was told i can use a stock 94-96 one
Thanks!
Old Dec 28, 2010 | 12:34 PM
1STGENFARMBOY's Avatar
First off you started with 160 hp stock, now how much pump tweeks are we talkin, if it's maxed out just before runaway then maybe at best,
210-225, with a good tight converter or a good clutch.
Old Dec 28, 2010 | 01:05 PM
The guy I got it from said it was 180hp and the sticker on the cover says 180 The truck has 340,000 the Engine was changed 60,000 ago so i was just going with the sticker and the guy i bought it from.
Pump it up just from runaway.
Smokes pretty good when i stand on it then clears up and moves out pretty good.
Old Dec 28, 2010 | 02:25 PM
is it a p-7100 pump or a VE
1993 5.9L Cummins I-6 160 2,500 400 1,700
1992 5.9L Cummins I-6 160 2,500 400 1,700
1991 5.9L Cummins I-6 160 2,500 400 1,700
1990 5.9L Cummins I-6 160 2,500 400 1,700
1989 5.9L Cummins I-6 160 2,500 400 1,700
Note: We are not responsible for errors or ommissions. Please consult a service
Last edited by 1STGENFARMBOY; Dec 28, 2010 at 02:27 PM. Reason: Automerged Doublepost
Old Dec 28, 2010 | 09:15 PM
dieseldawg's Avatar
guessing is for dreamers !!! get on the dyno so you can have proof!
Old Dec 29, 2010 | 05:20 AM
JBradley500's Avatar
180rwhp seems right.
Old Feb 8, 2011 | 12:02 PM
dieseldawg's Avatar
the sticker on what cover??? the valve cover?? haha
joejack6.0
Oct 25, 2014 05:41 PM
dougcarlo
Oct 18, 2014 03:15 AM
