518 Vs 618 Guru's?
Old Dec 27, 2010 | 08:29 PM
TurboBu's Avatar
Default 518 Vs 618 Guru's?
Wanting to do a 12v swap and I'm finding some low mileage pre-Ram trucks but no '94 up 12v trucks. So what are the differences/advantages that the 47 trans has over the 46?
Old Dec 28, 2010 | 08:22 AM
welderboy250's Avatar
a 46 wont take it if u make any power at all. the 47 has more clutches in the drums and i think more planet gears. also an old 518 wont have converter lock. also be aware of 47rh vs. 47re u MUST have a computer and associated wiring/sensors to use a 47re. the e makes is electronic regulated. the rh has a mechanical governor to control line pressure. the only thing it needs electricity for is to turn on OD and lockup.
Old Dec 28, 2010 | 09:44 PM
TurboBu's Avatar
where's the year split between rh and re?
Old Dec 29, 2010 | 05:29 AM
95-96 range. 96 i think are all re but im not sure if any 95 were or not
Old Dec 30, 2010 | 09:28 AM
cumminspwr11's Avatar
94 and 95 had the rh, some late 95 many have gotten the re but not completely sure, just look for a 3 pin connector and and not the 7 pin, i know a guy who may have a rh case and most of the parts you need for it
