Looking at a 6.5
Old Dec 27, 2010 | 04:03 PM
snwmn584's Avatar
Default Looking at a 6.5
Alright guys, I'm new to this thing. I did some searching and found some good information, but i have a few more.
Here is the truck i am looking at. It is a 1996 Chevy Silverado 1500 6.5.
View Inventory
Well i went and looked at it today after work and noticed a few things. They told me that they had the truck plugged in for 30 minutes before i had gotten there. Well the truck wouldn't start. I let the glow plugs do there job and tried a few different times and still nothing. While cranking i looked into the mirror and noticed it was blowing black smoke. The guy told me that it usually starts when being plugged in for 10 minutes, but i have a feeling the truck has been sitting there for a while.
The other thing i noticed was oil leaking somewhere in the front of the engine. Not sure if it was the front main seal or what.
And the crossover pipe had been fixed, and i noticed some of that muffler epoxy...
Other than that the truck was clean, no rust, good tires, clean interior.
They are asking 6188. 194000 miles.
What do you guys think? Any other help would be greatly appreciated.
Old Dec 27, 2010 | 05:12 PM
Crazy's Avatar
look clean
now for thing that can be wrong could glow plug system , PMD , OPS , LP or old injectors and it could be bad grounds buy bet you in fuel system some where
What kind temps do you have and ask when last time he put fuel in if it was summer fuel wouldn't have winter blend that make for very hard starting
Old Dec 27, 2010 | 05:21 PM
snwmn584's Avatar
It was only in the mid 20's when i looked at it today. I am going tommorrow to look at it again. I will ask about the fuel. I was thinking about the fuel delivery problem.
Old Dec 27, 2010 | 05:26 PM
Crazy's Avatar
Oh one other thing just came to mine is batteries if there not up to full power the engine won't crank faster enough
Reference Material: Hard Starting
So, you say you have hard starting?
Well, this is a common problem, for many of the years of diesels that GM had. However, the problems are altogether different. For pinning down exactly why you may be having a hard-start issue, you’ll first have to start with what type of engine and fuel system you are working with.
Now, before we get into the complexities of the fuel system, let’s eliminate something simple first. If you have a hard start condition when cold, it may be a simple glow plug issue. Check your glow plug system first before proceeding to make sure it is operational. Glow plug problems are most noticeable in cold weather conditions. You will usually get a lot of white smoke on startup. This usually indicates insufficient heat for ignition.
Now, if your glow plugs have passed the test, forge ahead into the pool of diesel.
There are two main types of “systems” we’ll call them. First is mechanical injection, and the other is electronic injection.
Mechanical injection is found in years up to 93
Electronic injection is found in years after 94
Maybe you are a little confused, and your application maybe a step van, or something other than the norm. How do you identify your type of fuel system? Check the model of the injection pump. You’ll see a number system such as this:
DB2-4911
DS4-5521
Now, there are various numbers that you will see, but basically you are looking at the first three letters. DB2 is mechanical, and DS4 is electronic. You can also be tipped off by the “PMD.” The PMD is the little black box that usually resides on the side of the injection pump. (Fondly referred to as the IP) So, a PMD will mean electronic, unless of course someone stuck one in for decoration. That’s not common though.. . ..
DB2’s are still out there, but they are getting fewer and fewer. DB2’s commonly have an issue with a no hot start issue. This usually occurs when you have a worn head and rotor within the injection pump. If you have a no hot start, do this simple test. Take about a pint of room temperature/warm water and slowly pour it over the injection pump. This will cool it down and you may be able to then start. Now, notice, this is not a GM “approved” test procedure, but it will show if your IP is to blame or not. Please also note, do not use COLD water, but a moderate amount of room temperature water. Too much may cause thermal shock and something further down the line to crack.
Can I fix my head and rotor? For the most part, no, you’re not going to be able to do this on your own. A fuel shop that works on these pumps will be about the only way you can go. Replacement of the injection pump may be another way of fixing this issue.
Now, the DS4 pumps have different no-starting issues. They rarely have the same hot start problem that a DB2 has, but it has happened. Some of the many issues that arise with them are caused with the PMD.
How do I troubleshoot and pin down if it’s a PMD or not? There is a whole thread devoted to the PMD and you can go there for more information on that. A PMD usually has an intermittent failure, as opposed to what you may find with a mechanical injection pump, that just won’t plain start. Not so say that a PMD would just outright die on you, but this seems to be a lesser found case.
Fuel supply issues. Make sure that you have a working lift pump and OPS. These two things will frustrate getting the engine started because the injection pump has more work to do.
Are there any other problems with the DS4 pump? Well, the nice thing is, the computer will usually tell on you and pop a code. Depending upon the code, you may get extended cranking time to get your engine started. If your Service Engine light (SES) is on, have your codes checked. Up to 95 is OBD-I style, and you can check it yourself with a paperclip. After that is ODB-II style, and you’ll need a code reader.
Cranking speed - A diesel must have good cranking speed for it to start. A slow turning engine will not get the heat built up, and the injection pump turning fast enough for it’s pumping needs.
My engine is not cranking fast enough. Where do I start? Well, several different contributing factors will slow down the speed. They are:
Battery cables - a known weak spot in the charging system. Poor contact, corroded cables and the side post setup are all causes for electrical woes.
Batteries - diesel engines are very hard on batteries. You have to rob about a hundred or so amps just for the glow plugs - then you really sting them with starter trying to turn a high compression engine. You may get 5 years out of your gas engine batteries, but don’t be surprised if you are changing your diesel batteries more often. If your batteries are in doubt, you can have them removed and tested.
Starter itself - if your starter is getting weak, it may not be turning up to full speed. Check all the above first, before deciding upon repairing or a new starter. Many have posted improved cranking speed from improved connections alone.
Maybe you’ve got a situation where you have a no-start condition. One of the things you can do, is check to see if you have fuel coming to the injectors themselves. This is the last part of the fuel system itself. Simply loosen the nut on the back of the injector and see if fuel squirts out while cranking. If you have no fuel there, you’ll have to back track and figure out why. Now, just because fuel because fuel maybe there, does not mean that there is enough pressure to “pop” the injector open, but fuel delivery to that point will help better understand what’s happening where.
Air leaks - in the fuel system too may not be helping matters any. Check around the fuel filter bowl and see if you have an oily residue under it, in the engine valley. If your filter is leaking, it may pass some air through the system. Filter bowls can be rebuilt inexpensively.
Fuel cap - this may not be the outright cause of a hard start issue, but it may not be helping either - especially if you have any type of air leakage in the fuel system. When you remove your fuel cap, you may hear a slight "hiss." But if you are hearing a long WWOOOSSHHH - time for a new cap. Make sure that it is a DIESEL cap. Gas caps will NOT work. Diesel caps are vented to prevent vacuum from building, although a very slight one will build.
There will be additions to this post as time goes on.
Maybe you don’t see anything here that would contribute to why your engine is not starting. Start by posting your findings from what you’ve gathered thus far. From there, we will be able to clue you in better possibly after providing more details about your truck. Remember to place that information in your signature line, because it helps all of us immensely to pin down your problems more effectively.
Old Dec 27, 2010 | 10:46 PM
Livelli's Avatar
Make sure to ask if it starts good with starting fluid. If the guy replies with anything other than "what are you, crazy? That'd kill this thing." just thank him for his time and walk away. They used ether on the ambulances where I work, until my third day on.
Old Dec 28, 2010 | 04:23 PM
snwmn584's Avatar
Alright guys, went and drove the truck today after work. He told me yesterday that he was gonna have it inside when i got there, and i actually was pleased when i got there it was still outside plugged in. Well Started right up. The truck ran great purred right along. I didn't know what to expect for power as i have never rode in a 6.5. Well its definetely isn't a duramax.
One thing i noticed was when i let off the gas rpm's would go down and there was a slight clunk. I'm kinda leaning towards maybe a transmission issue?! Almost felt like there was something loose.
Here is another question that i know you guys can answer, what kind of gains can i expect from a crossover, 4" exhaust, intake? Even turning up the boost and a tune?
Thanks for all the help you guys have been!!!
Old Dec 28, 2010 | 04:47 PM
Crazy's Avatar
it will feel like other new after you do cross over and 4" exhaust and put TM on turn it up to 12 psi hoping it won't set SEL off
Also fine a 97+ air box for better air flo
Old Mar 4, 2011 | 05:02 PM
racedaymechanic's Avatar
check out my website Home Page for Battery Cables
airspeed181
Jan 19, 2015 09:00 PM
Levis95
Jan 11, 2015 01:54 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
