Still will not start
Old Dec 27, 2010 | 12:15 PM
dodgeflatbed's Avatar
Default Still will not start
My truck will not start. It was taking a while for the lift pump to shut off, and was about 200-300 psi low when idling... i replaced the lift um.... but still will not start. It will start with a little bit of brake cleaner or WD40... After it starts and runs.... it doesn't sound normal... I drove it about 1/2 a mile, and it will not accelerate like it use to... very very slow, even when kicked into overdrive. When in neutral, and the accelerator is pushed down, it goes to 3000-3500 rpm and hold there for 5-10 seconds before it comes down, and even then it does not go back to idle. The code for the high pressure regulator is coming on, but could this cause all those problems? Could the SMARTY cause all of this? tanks for the help...
Old Dec 27, 2010 | 05:19 PM
cummin_un_glued's Avatar
FormerVendor
what rail pressure setting do you have the smarty set on?....4?....if so that can cause the CEL to come on....sounds to me like the FCA might be stuck...would cause all of the above simptoms...if it is stuck in the middle of its range it will be feeding the engine too much fuel at low rpms causing the fuel clatter sounds then at higher rpms it will not be feeding enough fuel to the rail and will cause the low power/low rail pressure...would also cause the CEL for a high rail pressure issue at low rpm
Old Dec 28, 2010 | 11:56 AM
The smarty has been changed arounded from 2-4 since ive had it Which was about February of last year.... However, it was reprogramed back to stock before we even started it back up.... And i am 18, so I need a little help... what is the CEL and FCA? thank you
Old Dec 28, 2010 | 04:22 PM
CreeperSleeper's Avatar
CEL = Check Engine Light
Old Dec 28, 2010 | 04:48 PM
FormerVendor
FCA = fuel control actuator....located on the rear of the cp3 injection pump has a 2 wire plug on it and is held on with 3 T25 torx screws
Old Dec 28, 2010 | 05:28 PM
Ok, thats what i was looking for, i wanted to get a second opinion on it, i have a guy lined up with a FCA already... thank you for helping diagnose, i will let you know once i get the new one on...
Old Dec 28, 2010 | 11:00 PM
FormerVendor
keep us posted
Old Dec 30, 2010 | 10:14 PM
replaced it, truck STILL will not start on it own, still needs a little wd40 once its started, it does sound better, accelerates better, but still is not what it ought to be. when in park and given gas, it still holds an erratic idle and doesnt come down for 5-10 seconds. drove it down the road, theres a small pinging noise that you can only hear when your driving. i also accelrated then let go of the pedal, and it held that speed for 2-5 seconds... i need help still!
Old Jan 4, 2011 | 07:48 AM
Here_Have_A_Bullet's Avatar
Is it throwing codes?
Old Jan 4, 2011 | 11:44 PM
Yea, but almost a different one everytime. recieved a paper from the dealer though, they are now covering the ECM on 2004-2005 Trucks because they had problems with it, so that might be it
