problem maybe fuel, maybe timing maybe valves
Old Dec 27, 2010 | 02:58 AM
95 12v dually's Avatar
Default problem maybe fuel, maybe timing maybe valves
my truck had a fuel problem when i got it, when i put it to the floor it would spit and sputter. i thought it was just the valvesso i adjusted them, that helped a little, put injectors in it( bosch 370) no difference but more power, put a lift pump in it, big difference. but still runs rough. drove about 30,000 miles and now its back. so i put the old injectors back in and adjusted the valves, that helped alot but still has a slight miss on heavy acceleration. other than that it runs fine. i think its delivery valves but havent got to get thm yet. any info or thoughts helps
Old Dec 27, 2010 | 09:40 AM
biged681985's Avatar
sounds like it could be the over flow bolt. have u replaced it yet?
Old Dec 27, 2010 | 11:16 AM
No I haven't, the banjo bolt for the supply line and return line on the top of the fuel filter housing?
Old Dec 27, 2010 | 11:50 AM
blazier18's Avatar
no theres a overflow valve in your pump
Old Dec 27, 2010 | 02:47 PM
the return line coming out of the pack of your injection pump has a banjo bolt that restricts fuel, and when they go bad, they will do what your describing
Old Dec 27, 2010 | 04:32 PM
Ram Diesel Injector Pump Problems
http://dodgeram.info/tsb/1996/14-07-96.htm
Old Dec 27, 2010 | 10:38 PM
Where can I get a new one? Cummins?
Old Dec 29, 2010 | 02:58 PM
blacksmoke82's Avatar
i had one that was doing the same thing an we advanced the timing and it ran great
Old Dec 29, 2010 | 04:03 PM
yes.
Also many of our sponsors should have them
Theres also these guys:
CUMMINS - Fuel System - Tork Teknology
Old Dec 31, 2010 | 03:03 PM
Overflow valvE didn't seem to change anything, swapped with a buddies that purs like a kitten, but it didn't change anything
