98.5 Twin Turbo Upgrade
Old Dec 26, 2010 | 11:15 PM
Big Kehoe's Avatar
Default 98.5 Twin Turbo Upgrade
So I am reciving a set of twin turbos from my brother in law and i want to know how much hp i will be gaining. I know i all varies but i was just wondering. I would also like to know any onther mods i should do to keep up with them.
Thanks
Old Dec 26, 2010 | 11:24 PM
jake 94's Avatar
Be glad to give some advice fill out your signature and tell us what you have rite now. What kinda compuonds are you getting?
Old Dec 26, 2010 | 11:42 PM
Big Kehoe's Avatar
Sorry I dont know much about them ill ask him asap though
Old Dec 26, 2010 | 11:55 PM
jake 94's Avatar
Well the first thing you gotta do is get a fuel pressure gauge and a fass or airdog to keep your fuel pressure in check then if you want to one day you could add some injectors and a better fueling box like and Edge juice or comp or a quad addrenaline box the juice and quad come with displays for all your gages like FP, EGT,trans and boost and all other things. Also if you have a manual your gunna need a clutch if its an auto get a good converter and valve body and remember to keep boost under 45psi to make sure you don't lift the head and blow a headgasket
Old Dec 27, 2010 | 12:02 AM
Big Kehoe's Avatar
the turbos are Hx35 and a Hx 55
Old Dec 27, 2010 | 12:08 AM
jake 94's Avatar
I'm using the HX35 as the top turbo in my setup also but I don't no anything about the HX55 sounds like a nice turbo for a bottom turbo tho
Old Dec 27, 2010 | 12:14 AM
Big Kehoe's Avatar
Thanks I cant wait to get them on.
Thanks for the info
Old Dec 27, 2010 | 12:47 AM
biged681985's Avatar
what all is done to your truck right now? with out knowing what injectors, programmer/downloader u have, lift pump, we cant even come close to telling u how much. also, is your truck an auto or manual, and is it set up to hold the power. theres alot more to it than just throwing twins on.
Old Dec 27, 2010 | 08:31 AM
RAW's Avatar
RAW
Agreed, we can be more helpful when we know what we are dealing with. Let us know what you have, and what mods have been made, from there we can give TOO much advice.
Old Dec 27, 2010 | 02:34 PM
Big Kehoe's Avatar
My truck is an auto trans stock
Stock fuel supply
Stock injectors
4" straight pipe
Ez chip by edge
Drip in k&n
6" lift with 35's
