misfire or rough idle at cold start up?
Old Dec 26, 2010 | 09:38 PM
cumminspwr68's Avatar
Default misfire or rough idle at cold start up?
I have a 07-2500. 5.9 with 56,000 miles. recently when i start it up first thing in the morning, it starts up but idles ruff like a misfire for about 3mins, and then it runs and idle fine after that. Fuel filter has been replaced and i donot have any check engine light or codes on. Any ideas ? Thanks for any help.
Old Aug 29, 2011 | 11:27 PM
nick9004's Avatar
Hey, did you ever find out what was causing this issue?
Old Aug 30, 2011 | 08:48 AM
dangerous1965's Avatar
+= Bad injector!
Old Aug 30, 2011 | 11:19 AM
nick9004's Avatar
I'm starting to lean towards bad injector but how do I find which one. Ive done a return flow test which passed... was going to ohm them out today. Any other tests for injectors?
Old Sep 1, 2011 | 10:36 PM
ws6tester's Avatar
Default ways to check injectors
A friend of mine who has worked on big diesels for years said they would use an ir thermometer to monitor each exhaust port temp at the manifold after startup with throttle held above idle and watch for one port/manifold to stay cold longer than the rest. Or from startup above idle they would use a tire paint marker and mark each manifold port area and see which paint mark stayed longest as the others melted. Good luck.
Old Sep 7, 2011 | 11:09 PM
ws6tester's Avatar
On a 3rd gen you can remove the valve cover and remove a wire from the injectors one at a time and whichever gets rid of misfire or engine reacts the least is where to start.
bdbfam
Aug 31, 2015 09:06 PM
ctjkelley
Jun 3, 2015 06:01 AM
cdetterer
15
Dec 8, 2014 08:46 PM
custom7.3
Nov 23, 2014 10:44 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
