4k Springs??
Old Dec 26, 2010 | 03:57 PM
Killacams's Avatar
Default 4k Springs??
I was thinking about puttin some 4k springs on and i was wondering how man rpms i can turn suppose to the stock ones??
Old Dec 26, 2010 | 03:59 PM
blazier18's Avatar
stock the fuel quits at 2200 the 3gsk stops at 2800 and the 4gsk stops at 3800. and id reckon a 3 revs to 3 and a 4 revs to 4 correct me if wrong
Old Dec 26, 2010 | 04:37 PM
c12vpwr's Avatar
you can get over 4000rpm with a 4k kit but if u dont have 60 pound valve springs bc you will float your stock valves at 3200rpm and if you are on a stock trans you need to work on that before u do anything else i learned the hard way the i also seen in your sig u said no fuel plate u need to put that back in the truck bc u actually lose power by taking it out u need to grind the foot off of it and slide it back but while u do this push the throttle and in the pump you will see a foot come out if that foot misses the plate u slid to far make it ti where it just hits it but not miss it
Old Dec 29, 2010 | 02:27 PM
BRE's Avatar
BRE
You don't always lose power.
Old Dec 31, 2010 | 11:23 AM
Neibe's Avatar
O.K this is probably a stupid question but what happens if you float your valves?
Old Dec 31, 2010 | 02:29 PM
94 12valve's Avatar
the piston will hit the exhaust valves
Old Jan 1, 2011 | 08:55 PM
Neibe's Avatar
OK I better only go 3k i don't want to mess with putting new springs in.
Old Jan 1, 2011 | 10:28 PM
blazier18's Avatar
if u ever plan on alot of boost down the road go ahead and get the valves and still do a 4gsk
2FordStrokers
Tire, Wheel & Suspension
Jan 5, 2015 09:23 PM
POWERSTROKEMANIAC
Dec 30, 2014 11:32 AM
Gdairyfarm
Dec 9, 2014 10:14 AM
jcottonoir
Nov 28, 2014 12:38 PM
Sep 29, 2014 03:00 PM
