Fuel plate?
Old Dec 26, 2010 | 01:13 AM
Rangerrick's Avatar
Default Fuel plate?
I have a 97 cummins, 5 speed. It was stock when I bought it at 114000 miles. Pretty good find. Anyway, I has straight pipes and an intake. I've adjusted the rule plate but I was wondering for the most power throughout? I was reading about them and I was leading toward a #10 plate then I found out about the #100 plates. My goal is to reach 500 horses. I'm going to order the plate then get the injection pump. I'm looking at going with a 150 gph fass. Anyway, if anyone can help me build this beast, your advice will be greatly appreciated!
Old Dec 26, 2010 | 02:27 AM
navalseabee's Avatar
get guages first and foremost. read the afc tuning and modding threads. i run a zero plate in my truck some people dont like it but it works great for me. also if you have a hack saw,grinder and sand paper save some cash and make your own plate. you can find template on ths site. oh and welcome to dieselbombers
Old Dec 26, 2010 | 05:36 AM
Rangerrick's Avatar
I know the answer to this question is yes but just to be sure, can I run a #100 plate with the afc mod? And where is a good place to shop for gauges?
Old Dec 26, 2010 | 08:52 AM
vinylman's Avatar
your better off going with no plate and doing the afc mods. ( there's alot of threads on this) but you definitely need gauges first and start saving for an aftermarket clutch.
Old Dec 26, 2010 | 08:56 AM
monster12valve's Avatar
go to the "request a price" link. our sponsors will hook u up right!
Old Dec 26, 2010 | 02:05 PM
oklahoma_6speed's Avatar
put the plate in the glove box.... that way you can say there is a plate in the truck...
Old Dec 26, 2010 | 04:50 PM
c12vpwr's Avatar
dont take the plate out i put my truck on a dyno with out a plate and lost power to having a grinded #0 plate slide back about a 1/4 of an inch to where when u hit the throttle the foot in the pump just hits the plate dont let it miss it
Old Dec 26, 2010 | 06:46 PM
Rangerrick's Avatar
I'm going to keep the plate in the afc because your egt's will go crazy and the rack has a potential to lock up if I take it out, Im not ready to kill this truck yet. Thanks for the input though guys. I'm still debating between the #0 and the #100 plate. I'm building it for sand drags. I've got my gauges and clutch (dual-disk) on order. I'm just getting the fuel setup together so I can throw all this together at once.
Old Dec 27, 2010 | 09:58 AM
shortbusdriver's Avatar
Tune your truck properly and you wont lose hp if you have the air to back it up.
Taking your plate out does not have any more potential to hang the rack. There are two different rack stops located in and outside of the pump that prevent it from traveling to far.
Old Dec 27, 2010 | 02:06 PM
Mistress's Avatar
I put the fuel plate in the glove box. and got a better fuel filter. it made my truck run so much better! and didnt change my milage that much at all
