turbo help
Old Dec 26, 2010 | 12:07 AM
97 dodge 12 valve's Avatar
Default turbo help
i just got my gauges in and i am only getting ten pounds of boost. anybody got any ideas
Old Dec 26, 2010 | 12:14 AM
Haden's Avatar
Boost leak, screwed up AFC (holding fuel back), screwed up boost gauge. Does it have any power? With only 10psi it should be pretty slow and never really spool up.
Old Dec 26, 2010 | 02:16 AM
fivepointohno's Avatar
what gauges are you using?
Old Dec 26, 2010 | 12:46 PM
they are glow shift gauges and i checked for boost leaks and everything was good
Old Dec 26, 2010 | 03:57 PM
blazier18's Avatar
wats ur mods? boost elbow?
Old Dec 26, 2010 | 04:40 PM
c12vpwr's Avatar
where did u hock the guage up at i have glow shift guages to and mine workc fine also is your gauge manual or electric
Old Dec 27, 2010 | 01:48 AM
i have my gauge hooked into my airhorn and they are electric and i just have 100 horse injectors
Old Dec 27, 2010 | 02:37 AM
c12vpwr's Avatar
if the are electric u should have a little sending unit that hocks up to it some where if it manual its just a ruber hose that runs to a fitting then to the gauge if its electric you need to call the place u got the guage from and tell them what its doing they will send you a new sending unit and if its manual check the hose for holes good conections and if it is kinked or pinched in something i had the same problem with my manual guage and it was getting pinched in between the a support and the guage pod
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
