Smarty Question
Old Dec 25, 2010 | 10:29 PM
Smoke 'em's Avatar
Default Smarty Question
Smarty sr. or Smarty jr. for 24v ???
Old Dec 25, 2010 | 10:59 PM
J-Pipes's Avatar
I have the big Smarty, with the revo software, and I realy like it, seems to have a lot of features, has a decent amout of tuning options that are easy to understand and use. The Smarty may not add as much top end peak power as some of the other chips/tuners, but what it does add is 100% usable, off-idle power. Hope this helps u
Old Dec 26, 2010 | 09:47 AM
Smoke 'em's Avatar
What is the Revo software?
Old Dec 26, 2010 | 09:52 AM
J-Pipes's Avatar
It alows you to adjust the tourque management, injection duration and injection timing, between 5 pre-set options for the tourque and timing, and 4 options for the duration.
Old Dec 26, 2010 | 09:55 AM
Smoke 'em's Avatar
oh alright So would you recommend a smarty or injectors first?
Old Dec 26, 2010 | 04:16 PM
J-Pipes's Avatar
As long as you have enough fuel supply, I don't think it would make much difference which one you got first, but I think I would go with the Smarty first, for the extra features, such as code reading, speedo corection and such.
Old Dec 26, 2010 | 05:47 PM
dieselboy88's Avatar
If you do go with the chip then make SURE the next upgrade you do is a better fuel pump to push that extra fuel. If you don't then eventually the stock lift pump will crap out and then the injector pump will follow suite. And that's a minimum 1000 dollar fix. Just in case you didn't already know.
Old Dec 26, 2010 | 06:01 PM
johnyb59's Avatar
there's only a "SR" for the VP crowd. The Jr. is for CR
Old Dec 26, 2010 | 06:32 PM
J-Pipes's Avatar
Thats what I thought, but wasn't sure so I didn't want to say.
Old Dec 26, 2010 | 08:13 PM
Smoke 'em's Avatar
This may be a dumb question but what is VP and CR???
