Replacing glow plugs and injectors.
Old Dec 25, 2010 | 10:21 PM
austin26372's Avatar
Default Replacing glow plugs and injectors.
I've got a service record that came with the truck; it was used as a welding rig.
The GP's were replaced about 35,000 miles ago.
Injectors haven't been touched.
The truck was maintained properly up to 100,000 when it was sold to the second owner. 30,000 miles later, I'm let to clean up what owner number 2 messed up.
Question is: should GPs be replaced on a regular basis, or as needed? Same with injectors.
I just feel that the truck doesn't run as it should.
Old Dec 27, 2010 | 10:07 AM
DieselCrawler's Avatar
gp should be replaced as they fail. injecotrs should be replaced as a matched set. if it never had injectors, it is time.
Old Dec 27, 2010 | 12:41 PM
Thanks for the info!
Old Jan 1, 2011 | 09:08 AM
fury9's Avatar
only use motorcraft beru GPs. do not use autocraps or anything else or you will be kickin yourself in the *** when one swells up and gets stuck in the head.
Old Jan 1, 2011 | 02:01 PM
CARP's Avatar
I use Glow Plugs from this site. Glow Plug - Ford 6.9 L IDI (Spade Terminal)
Truck starts on a half crank even in single digits. They also make good injectors and lines.
Metz1234
Mar 3, 2016 10:20 PM
klein444
Mar 8, 2015 11:42 AM
