what could be wrong?
Old Dec 25, 2010 | 06:12 PM
95 cummins ole smokey's Avatar
Default what could be wrong?
ok i have a 95 cummins and it has 140hp injectors, #0 fuel plate, little work done to injecton pump, it ideals fine and runs fine but when i put it to the floor it studers and puts a little cloud of white smoke out? what is could it be? a friend said an injector might be bad, or the lift pump is going out, or the injection pump needs to be turned up more? but i dont want to harm the tranny or clutch, some one help
Old Dec 25, 2010 | 06:42 PM
lodal cummins's Avatar
i really think those injectors are a tad bit too big for that stock charger. plus a 0 plate and 140 injectors will toast the clutch if it is stock. white smoke usually means raw fuel! so it could be a bad injector washing you cylinder walls take a whiff of your tail pipe and see if it smells like raw fuel. or it could be possible you timing has slipped. that is just my 2 cents!!!!!
Old Dec 25, 2010 | 07:18 PM
the clutch seems to hold up just fine, how do i check the timing
Old Dec 26, 2010 | 04:54 PM
c12vpwr's Avatar
check your fuel filter and pre-screen filter my 96 did the same thing when i got it and thats what it wa if thats not it i would check injectors
Old Dec 26, 2010 | 10:45 PM
leroyb1138's Avatar
did you check the bothem fuel filter above the starter
Old Jan 6, 2011 | 07:59 PM
yea i took it off and turned the filter up side down and mud started falling out from it and i replased the filter with a new one and it still runs a little better but still pops and smokes when thrased on the gas.
Old Jan 7, 2011 | 05:31 PM
96blackcloud's Avatar
this sounds like a timing problem to me, or a possible air leak. check for leaks in ur fuel lines the especially the rubber lines after the fire wall, did you replace the injector washers with new washers when u put them in? if no leaks are visible check fuel pressure. if its not a leak then ur timing has slipped and it will need to be re timed
Old Jan 10, 2011 | 09:13 AM
leroyb1138's Avatar
there is a second take this off and clean it with gas let it drie then fill with diesel and put it on
when you start the truck you will have to hold bout 1500 rpm for a minit or it will die and then its a bear to start back
Old Jan 10, 2011 | 11:20 AM
94 12valve's Avatar
check your timing, you will need to find someone that has the timing tools, take it to a shop to have done, or pin time it back to stock.
Where are you located?
jjbced
Jul 19, 2015 10:03 AM
gumborancher
Apr 24, 2015 01:25 PM
Bob V
Apr 6, 2015 11:02 PM
nelly559
Feb 2, 2015 08:19 AM
cutthroatxxx
Nov 16, 2014 09:11 PM
