Exhaust... Single Stack
Old Dec 25, 2010 | 04:23 PM
austin26372's Avatar
Question Exhaust... Single Stack
I'll post in here, but this is out here for anybody to add to.
I'm looking at a single stack, something like 4 or 5 inches. I don't care to do double.
Here's my concern: water. Should I worry about water intrusion, or rust? (I'm thinking long term here)
Second question: where the heck can I get a single stack in black without paying $400?! (Need reducer, flex pipe, mounting bracket, etc.)
Old Dec 25, 2010 | 07:23 PM
DieselCrawler's Avatar
make it yourself. mounts are easy, flex and the pipe can be bought from any truck shop. use high heat paint to make it black.
as for water, keep a coffey can in the truck. cover the stack when not in use.
Old Dec 25, 2010 | 09:15 PM
I thought about making it myself, but truck shops are far and few between around here.
There's a local metal supply, but the only 5inch he carries is 4ID.
Clever idea with the coffee can, I'll remember that one!
Old Dec 28, 2010 | 06:29 PM
Hegel122's Avatar
chromestackmafia.com they are really cheap
Old Jan 6, 2011 | 09:19 AM
green thang's Avatar
napa got a 4 inch stack and everything to reduce it down to my 2.75 exhaust. sounds good. water and stuff put a flapper on it 20 ucks at napa
Old Jan 6, 2011 | 11:47 AM
cbsmoraine's Avatar
silverline makes a sweet single stack kit. as for water, drill a hole at the lowest point in your exhaust (generally at the 90 going up thru the bed) doesnt have to be a large hole i would say nothing larger than a 1/4 inch. it will act as a weep hole and drain out any water that enters. no worrys about rust provided your truck is a daily drive and is stored in a garage. if you dont store it in a garage, i agree with the guy above, coffee can is cheap and it will keep your stack dry.
Old Jan 6, 2011 | 06:54 PM
FORD-INTERNATIONAL MAN's Avatar
napa sells 5 inch pipe now but u have to buy it in 10 foot peices at $150
Old Jan 14, 2011 | 02:20 AM
EasternAggie's Avatar
Yank one off an old semi, and buy some high temp flat black paint. You should be able to find everything else at auto stores.
Old Jan 15, 2011 | 03:34 PM
stackboy6.9's Avatar
you dont need to cover your stack.i hav dual 5inch stacks.the soot sucks the water up.and plus the water will hav to travel up alot of exhaust tubing to do anything.but if your still gona freak just drill a hole and weld a nut on above the hole and put a bolt in
oh and if you put a coffee can on ur stack your gona scratch it
Last edited by stackboy6.9; Jan 15, 2011 at 03:34 PM. Reason: Automerged Doublepost
Old Feb 8, 2011 | 02:37 AM
texfarmboy's Avatar
i saw one that somebody pulled off a old dozer that didnt look bad on a dodge but if i remember rite it was like a 7 inch maybe too much for wut you want though
