Where do i get this gasket???
Old Dec 24, 2010 | 02:47 PM
hiboy_76's Avatar
Question Where do i get this gasket???
My truck is leaking antifreeze, and i think its either the water pump gasket, or the housing that the lower radiator hose connects to, could anybody tell me where i would get that housing gasket if you know what i'm talking about.
Old Dec 24, 2010 | 04:22 PM
Rusty89Cummins's Avatar
it may not be wat you think. i thought it was the same thing on my truck but it ended up being my head gasket. it blew on me and was leakin internally and externally. does your truck smoke abnormally?
Old Dec 24, 2010 | 05:25 PM
Mark Nixon's Avatar
I'm with Rusty on this one, check it all over very closely.
The lower housing is sealed to the block with a heavy rubber 'O' ring, in a stepped groove, and seldom ever leaks.
Of course, the water pump is known to spring a leak.
Mark.
Old Dec 24, 2010 | 06:54 PM
hiboy_76's Avatar
well, i'm not getting water in the oil, it doesnt smoke abnormally, and its only wet at the bottom bolt on the water pump and at that housing. Still sound like the head gasket?
Old Dec 24, 2010 | 07:24 PM
Mark Nixon's Avatar
Then it likely isn't the head gasket.
Problem is, you might have to take it clear apart to figure out what it actually is.
I wasn't trying to be doom and gloom on ya', but liquids like coolant and water can be real tricky to track a leak source, especially with numerous possible leak points in 1 small area.
Mark.
Old Dec 24, 2010 | 09:16 PM
hiboy_76's Avatar
i know what your sayin, i'll have to take it apart as soon as i can get to it, the wierd thing is that it only leaks when its cold, once it warms up then it doesnt leak.
Old Dec 25, 2010 | 08:37 AM
hmm probly cuz when everythin warms up, whatever is leaking expands and stops the leak. its probly your water pump then.
caissiel
Sep 24, 2015 05:37 PM
JHALL30
Chevy/GMC Duramax 01-04 LB7
Sep 8, 2015 07:00 PM
scottw1513
May 2, 2015 08:16 AM
Diesel Addict
Price Quote - Request A Price
Dec 10, 2014 06:52 PM
1994cummims
9
Oct 15, 2014 11:37 AM
