any way to prime the oil pump on my old 91 ?
Old Dec 23, 2010 | 04:37 AM
ironworker's Avatar
Gear any way to prime the oil pump on my old 91 ?
I m doing a cummins conversion and the motor has been sitting for almost a year. and i m getting close to bring it back to life is there any way to prime to oil pump befor i start her up
Old Dec 23, 2010 | 06:55 AM
welderboy250's Avatar
if your workin on a 91 you will prob be better served in the future by posting in the first gen section. but as for your question there are several 1/8" pipe thread oil pressure ports on the engine including one on the oil filter housing right beside the turbo feed line. i have a small tank i hook to that port and fill with oil and then pressurize with air to push the oil into the engine. before i made the tank i used a new grease gun that the back end of the tube could be screwed off and used it on that port. fill it up and start pumping. works great just takes a little longer.
b&hbiz
Sep 9, 2015 07:53 AM
soco
Jul 27, 2015 06:06 PM
HardLuck
Jun 24, 2015 08:04 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
moneypitk5
Feb 12, 2015 11:01 AM
