Run away with 4k gsk
Old Dec 22, 2010 | 07:40 PM
truckinbiker's Avatar
Default Run away with 4k gsk
Ok so my truck doesn't truely run away cuz it shuts down properly. What it does do is if I start it up with my foot slightly on the throttle the RPMs just keep climbing, not extreemly rapidly but constantly and smoothly. If i start it without my foot on the throtttle at all it will idle, some times the RPM will climb alittle but then come back to idle. When I rev it though, if I go close to 2k it will just keep climbing. I was wondering if any one had seen this and if any one has any sugestions for fixing this.
Old Dec 22, 2010 | 08:28 PM
Whit's Avatar
Site Mascot
back of one click on the spring retainers
Old Dec 22, 2010 | 09:33 PM
biged681985's Avatar
what is your idle set at. on my dualy, when i first got it, i tried raising the idle up some using the set screw, and raised it a lil to high, and it was doin pretty much what u described also
Old Dec 22, 2010 | 11:31 PM
New_Dog_93's Avatar
My VE did something similar... it went from cruising speed to full revs but would idle down eventually and shut off. Turns out it had grenaded itself internally and needed a complete rebuild to the tune of $1300 Cnd.
Old Dec 23, 2010 | 01:34 PM
I back the retainer out one click at a time, and every time I loosened it the idle would get lower but I would have the same problem with the RPM's climbing once I reved it. Though as I loosened the retainers it would rev a little bit higher with out getting stuck and climbing, though even when the RPMs would return to idle it was a verry slow return.
Old Dec 24, 2010 | 07:44 PM
Pyro690's Avatar
Did it start when you put the 4GSK in?
Old Dec 24, 2010 | 10:15 PM
94 12valve's Avatar
you did take all the shims out from under the old springs right? and you also put the correct springs back in?
Old Dec 24, 2010 | 11:26 PM
Pyro690's Avatar
I was going toward the spring seats. The stockers are 2 piece. GSK are 1. If you didn't take both pieces out, it will want to free rev and return to idle slowly. Don't ask how I know.
Old Dec 25, 2010 | 12:29 AM
I'm pretty sure that is what I did, cuz I only took one shim out and the seat I took out was only as big around as the smallest or second to smallest spring. Gonna try this again next week and post up what happens.
Old Dec 25, 2010 | 12:58 AM
Pyro690's Avatar
Yeah. I fished with a magnet the first time and only got half the seat and a shim. Was a pain in the butt to drive. Took it apart again, got the rest of the seat and 2 more shims. Let us know what you find out.
vin_diesel
Mar 1, 2016 01:43 PM
Sep 16, 2015 12:20 AM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
rick-64
Mar 19, 2015 07:59 PM
wvwelder89
Nov 20, 2014 10:26 AM
