Fuel pressure gauge bad???
Old Dec 22, 2010 | 06:26 PM
Jeff M's Avatar
Default Fuel pressure gauge bad???
I starting noticing a rattle
ing noise coming from my gauges and it seems to be coming from my fuel pressure gauge. I don't see anything visually loose and think it could internal. Does this happen alot? I have isspro mechical gauges...
Old Dec 22, 2010 | 07:39 PM
RAW's Avatar
RAW
When does it rattle? Key on pump on, engine running, while driving? Is it pressure related? I ask it determine if it is a loose bulb, or something pressure related.
Old Dec 22, 2010 | 07:50 PM
Jeff M's Avatar
all of the above... i checked the bulb already. i read somewhere a needle vavle hepls if u dont run an isolator
Old Dec 22, 2010 | 07:56 PM
RAW's Avatar
RAW
Does the needle jump around?
Old Dec 22, 2010 | 08:30 PM
Jeff M's Avatar
it just vibrates alot. it keeps steady psi if that what you are asking.
Old Dec 22, 2010 | 08:33 PM
turbo20psi's Avatar
Its better to have a isolator,but if you have a needle valve try to close it a little more to keep the VP from making it jump around.
Old Dec 23, 2010 | 03:03 AM
You will quickly damage that guage if you dont put a needle valve or pressure snubber to dampen the pressure spikes from the VP-44.
Old Dec 23, 2010 | 07:02 AM
Jeff M's Avatar
Why isit just starting to happen now though. I have had the gauge isntalled for a couple of months and it didn't start making noise till recently.
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Jan 24, 2015 10:55 AM
