Stuck On Defrost
Old Nov 17, 2007 | 05:32 PM
Monster Truck's Avatar
Default Stuck On Defrost
On my 95 the cab air is stuck on defrost, no matter where I set it to it still comes out the defrost vents on the dash. I think the switch is working becuase the ac pump with cycle when you put it on defrost. Any Ideas as to whats going on? I reatched under at the actuator still moves so its not jammed.
Old Nov 17, 2007 | 05:37 PM
Uncle Bubba's Avatar
On my 99 the defrost is the default setting when I lose vaccuum pressure to control the door in there. I would assume it is the same on yours. Under the hood against the firewall you will see the black rubber vaccuum lines, just check them for leaks or any rotting rubber. Might even be one just came lose of the connection. This is assuming that all of your other vaccuum operated things still work. Cruise control, 4WD selector and so on.
Old Nov 17, 2007 | 05:43 PM
DBogo's Avatar
you have a vacuum leak somewhere, look around under the hood and see if you see one that isnt any good
Old Nov 17, 2007 | 06:29 PM
Cruise control works I havent put it in 4x4 yet but Im pretty sure it works. I will hunt around under the hood and see if i can find anything. Thanks
Well I found a line, it goes fron the drivers side right next to the brake master cylinder over the engine to the pasenger side above the exhuast and throught the firewall, its start out with like 3-4'' of rubber tube into one of the little plastic 3 way T's then into the plastic air like over to the other side, I cant find where its goes.
Heres some pictures of it.
http://i222.photobucket.com/albums/d...g/PICT0145.jpg
http://i222.photobucket.com/albums/d...g/PICT0147.jpg
http://i222.photobucket.com/albums/d...g/PICT0146.jpg
Last edited by Monster Truck; Nov 17, 2007 at 06:29 PM. Reason: Automerged Doublepost
Old Nov 26, 2007 | 07:25 PM
sawmillman's Avatar
My 97 did that under the dash on the drivers side tward the front of the trans hump almost out of sight there is a vac pod that controlls that the dealer does stock them make sure you take it with you there is about 4 or 5 diffrent ones.
Old Nov 26, 2007 | 07:33 PM
LOGANSTANFORTH's Avatar
my 95 V10 truck had the same problem but it just blew on the floor, it was vaccum, so i stuffed the floor vents full of socks and duct taped the holes shut, went through the vents after that........not the right way to fix it, but it got fixed......
bosse777
Sep 28, 2015 05:38 AM
Daniel Leipart
Jun 28, 2015 02:42 PM
Gm3500
May 7, 2015 11:01 AM
Bottlerocket12v
Mar 12, 2015 09:10 PM
cfarley0210
Jan 19, 2015 06:00 PM
