Lift pump
Old Dec 22, 2010 | 10:37 AM
big bear's Avatar
Default Lift pump
Has anyone out there installed a fass ddrp 02 and are they having good luck with it . Also is it easy to install. thanks for the needed help.
Old Dec 22, 2010 | 10:40 AM
stodg73's Avatar
I have not heard good things about the ddrp. I have installed an airtex and it is working so far, giving me about 18psi at idle and about 14 psi at 75mph.
The main problem with the ddrp, same as the airtex, is that it is placed on the block and is affected by the vibrations of the engine. The vibrations are what destroy the ddrp, and the stock lift pumps.
Old Dec 22, 2010 | 10:43 AM
Billy D's Avatar
Old Dec 22, 2010 | 12:18 PM
big bear's Avatar
Default lift pump
Thanks for the quick reply, would it be better to locate a inline pump near the fuel tank such as a holley blue and have it pump thru the stock lift pump. thanks again for the quick help.
Old Dec 22, 2010 | 01:20 PM
kerley's Avatar
Default lift pumps
I have a DDRP on my 98.5 Dodge Cummins. They have been re-designed and mine works just fine. 24 pounds at idle, 20 pounds @ 50-70 mph running empty and 17 pounds pulling a long grade pulling my Featherlite 16' G/N horse trailer. It is mounted on the block and I have had no problems with the pump. My truck is stock and works well for my needs.
I believe the Fass/ Air Dog mounted on the rail would be better but they can be a chore to install, and are more expensive. It's totally your choice. Good luck
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
