06 ram no reverse 5.9 48re tram
Old Dec 22, 2010 | 09:14 AM
km11tc's Avatar
Default 06 ram no reverse 5.9 48re tram
no reverse 48re tranny 06 2500 5.9 cummin all forward gears shift ok also shift in to overdrivr no code is the anything i can do short of a new or rebuil trenmission need help
Old Dec 24, 2010 | 01:47 AM
dangerous1965's Avatar
reverse and 1-2 are the same clutch packs. Must be a valve body issue. Is it stock? When you put it in R does it light up on the dash? Have you tryed hunting for it with the shifter?
Old Dec 24, 2010 | 07:44 PM
km11tc's Avatar
Default where my reverse
yes it is stock, no lights on dash at all no code yes tried hunting for it. can fell the same small movement when putting it in drive and reverse. thank for the info TC
Old Dec 25, 2010 | 06:48 PM
cerberus60's Avatar
You have manual 1st?
If so, could be several things but OD direct clutch problem jumps to mind.
Old Dec 27, 2010 | 03:00 PM
megacab's Avatar
check your bands in the transmission could be valve body or some broken internals.
Old Jan 3, 2011 | 06:48 AM
km11tc's Avatar
thanks for all the help problem still there i jacked the back whells off the ground put it in reverse the rear whells true and would speed up when i gave some gas dose anyone know what to do next
Old Jan 4, 2011 | 07:41 AM
Here_Have_A_Bullet's Avatar
More than likey the clutches are toast. The forward clutch would explain part of it but the direct clutches are probably the issue.
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
Gitana
Nov 25, 2014 06:25 PM
veggyoilkid
Nov 6, 2014 09:43 PM
Oct 4, 2014 10:10 AM
Sep 30, 2014 10:40 AM
