4wheel drive popping out! Please help!
Old Dec 22, 2010 | 08:35 AM
mcgardner83's Avatar
Default 4wheel drive popping out! Please help!
I have a Dodge 4x4 Turbo Diesel, and it keeps popping out of 4 wheel drive. It stays in if I'm going slow around 15-20 mph but any faster and I can feel it come out it's like running over something. Any ideas? It is snowing and I have to haul water so I need to know my options. Any help would be greatly appreciated. Thanks Melissa
Old Dec 22, 2010 | 09:12 AM
DanLowe's Avatar
Not to ask a dumb question, but are you sure the lever is pulled all the way back...and LOCKED in? Have you tried holding the lever in 4X4 to see if it will work that way?
Old Dec 22, 2010 | 10:13 AM
Default 4 wheel drive popping out
It's in as far as it will go. Is it possible it feels like it's in but that it's just not all the way? The light on the dash flicks when it makes a noise and pops out. We got stuck a few weeks ago and it's been doing it ever since. Could it be that we knocked something loose? I really appreciate the feedback. Thank you, Melissa
Old Dec 22, 2010 | 10:34 AM
DanLowe's Avatar
The linkage could possible be out of adjustment... do you have a Haynes manual? It will have all the specifications in it for adjustment...and to be safe, you should probably check your fluid level. One last thing, you should probably fill out your sig so we know all the details of your truck, I found in your profile it was a 99...but that was it. We need model, transmission, etc. thanks
Old Dec 22, 2010 | 11:49 AM
bluedieselram's Avatar
you may need a new quick connect(not sure if im calling it the right name)mine broke & when i tried putting in 4x4 it would come out & make a grinding noise,took about 20 mins to put new one in or ya pinion bearings need to be replaced
Old Dec 23, 2010 | 09:03 AM
Thank you for the ideas. Merry Christmas! Thanks Melissa,
Thank you for your help, I just joined so I don't know how to update my sig? I have a 99 Dodge Turbo Cummins Diesel 4x4 2500
Last edited by mcgardner83; Dec 23, 2010 at 09:03 AM. Reason: Automerged Doublepost
Old Dec 23, 2010 | 10:05 AM
to edit your sig go to the top of the page & click on "User CP" its the 3rd option from the top of the list
Old Dec 25, 2010 | 02:23 PM
redcummins04's Avatar
Shift fork went bad on mine and the main bearing went bad
Rauch65613
May 15, 2015 10:00 AM
Mar 19, 2015 08:10 AM
6.5dieselman
Feb 26, 2015 04:45 PM
MAC4232
Jan 28, 2015 01:46 PM
Oct 21, 2014 02:40 PM
