pmd
Old Dec 21, 2010 | 07:51 PM
thor08's Avatar
Default pmd
I have a 96 Chevy with a 6.5 and I wandering how do know or test to see if the pmd or injection pump is going bad?
Old Dec 21, 2010 | 08:39 PM
Crazy's Avatar
here some info on testing but to me is know someone with6.5 let try they on your truck is the best way
what happen with your truck
www.AccurateDiesel.com - PMD Installation Instructions - Accurate Technical Services, LLC
should have ask you also are getting any codes IP most of the time will gave code and pmd most time don't gave you any codes
Old Dec 21, 2010 | 08:42 PM
thor08's Avatar
Well it would run rough. Wouldn't idle right and now I can't get it to start back up at all
Their is no codes either that pop up. Check engine light doesn't come on. But I can't get my truck to start it only cranks.
Old Dec 21, 2010 | 08:44 PM
Crazy's Avatar
that are sign of PMD
is SEL on
Old Dec 21, 2010 | 08:49 PM
thor08's Avatar
What is sel?
Can u test the pmd? The pmd can stop it from starting if its bad?
Crazy's Avatar
service engine light
Old Dec 21, 2010 | 08:50 PM
thor08's Avatar
No its not on.
Old Dec 21, 2010 | 08:56 PM
Crazy's Avatar
are you getting fuel to the IP and have check LP to see if it working just cause you here it don't mean it working
the link i gave tell you how to test
yes PMD can stop it from starting
is you PMD on the pump , intake, or front bumper
Old Dec 21, 2010 | 08:59 PM
thor08's Avatar
What is the IP and I do not know if the LP is working for sure. I can hear it. And the pmd is on top of the intake.
Old Dec 21, 2010 | 09:05 PM
Crazy's Avatar
IP is Injector pump
ok open the T-valve and have someone turn the key on and fuel should pump out it
here other way but not sure if do it 96
Shown are jumpers on the 97+ Burb & truck makes it real easy to purge the filter after a replacement, also for force run to test lift pumps 12v to connector forces the run.
