how much vaccum should a 6.2 make at idle?
Old Dec 21, 2010 | 05:37 PM
92typhoon937's Avatar
Default how much vaccum should a 6.2 make at idle?
How much vaccum does a 6.2l make at idle?
Old Dec 21, 2010 | 06:09 PM
Crazy's Avatar
Yep.
step 1:
Connect a vacuum gage to the vacuum pump inlet. (the lower part)
where applicable disconnect outlet hose from outlet tube on the pump, and plug the end of the hose. dont plug the outlet on the pump.
with engine idling, vacuum should reach 70kPa/21"Hg minimum at sea level withen 30 seconds.
5,000 feet= 18"Hg
10,000 feet= 14"Hg
15,000 feet=12"Hg
if it checks okay, the leak is somewhere else in the system. go to step 2.
low vacuum= bad pump .
step 2:
remove the plug from the outlet hose(s) and reconnect same hose to the pump.
reconnect vacumm gage with a tee adapter with the gage located near the pump inlet.
engine idleing vacuum may be 10kPa/3"Hg less then the measured pressure in step 1 after one minute.
checks okay= problems not in the system .
checks low= check for leaks
Old Dec 21, 2010 | 07:19 PM
wildbill's Avatar
Or you can remove the hose from the vac pump and stick your finger over the port. If you feel good resistance, good pod. Not much or none, need a new pod.
Old Dec 23, 2010 | 02:28 PM
ok pump is good hooked guage to it directly got 22 vaccum i gues i need to chase it out of it hmm this thing is gettin on my nerves thanks guys
ok the thing on the side of the injection pump that controls the trans vaccum what should it be to the treans side before u rev it up
Last edited by 92typhoon937; Dec 23, 2010 at 02:28 PM. Reason: Automerged Doublepost
2500ctd
Jun 23, 2016 01:22 AM
MechanicalDiesel
Aug 11, 2015 08:14 PM
jedder21
Mar 7, 2015 09:47 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
