Gauge question/Boost question
Old Dec 21, 2010 | 08:15 AM
UglyTruck's Avatar
Default Gauge question/Boost question
all the boost gauges that i see are available in several different pressure ranges. how do i know what range to get, and this also raises the question what are normal boost pressures, what can i expect out of my minor mods and what is a dangerous amount of boost?
Old Dec 21, 2010 | 08:25 AM
RAW's Avatar
RAW
Dangerous would be 50+ before the head gasket is in question.
I'd suspect you could get into the 40PSI range with your set up, and a pinched wastegate. I'd suggest a 0 - 60 PSI gauge, unless you plan on more modifications. Then I would suggest a 0 - 100. I have a 60, and will soon need a 100.
Old Dec 21, 2010 | 08:26 AM
stodg73's Avatar
Depending on what you have as a turbo and what your wastegate is set at, will determine which boost gauge to get. If you think that you are pushing 35 psi all day, then you should look into a 60 psi gauge, etc.
On a stock truck with no mods to the turbo, the most pressure put out by the turbo is about 20 psi. With modifications, a HX35 will be able to put out about 30 psi all day, any high then you will start having turbo issues(larger turbo needed).
Old Dec 21, 2010 | 09:25 AM
We usually recommend the 60psi gauge unless your never going to upgrade.
TurboBoy6.5
Apr 12, 2015 11:22 PM
MrCat4974
Mar 23, 2015 11:30 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
scottxmorris
Oct 8, 2014 02:14 PM
