two piece exhaust manifold leaking at joint
Old Dec 20, 2010 | 08:27 PM
harleytn's Avatar
Default two piece exhaust manifold leaking at joint
1999,f650, with Cummins 5,9l leaking at expansion joint on the two piece exhaust manifold. Called Cummins dealer and he had said something about a sealant that could go in the joint? He didn't know the part # but told me he would call back with the # but he never did. Does anyone have a fix for this problem?
Old Dec 20, 2010 | 10:18 PM
RAW's Avatar
RAW
The only sealant I can think of is High Temp Silicone, but I doubt it would last very long. Some of the 2 piece exh manifolds on our Deere engines use metal seals. They are like a keychain design, but about 3 wide of a thin spring metal.
How much does it leak, cold or hot?
Old Dec 21, 2010 | 09:32 AM
harleytn's Avatar
Leaks enough to put soot on side of engine and the truck is very weak when pulling.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
