03 lost power steering/brakes won't release
Old Dec 20, 2010 | 03:55 PM
wyoranch's Avatar
Default 03 lost power steering/brakes won't release
Was driving the 03 in my sig, had to hit the brakes hard. When I released them the pedal stayed down, brakes were still grabbing. I can pull the pedal up with my foot and they release. Also, it lost all power steering. Ideas?
Old Dec 20, 2010 | 05:29 PM
Whit's Avatar
Site Mascot
interesting.................the powersteering pump and the vac pump to assist the brakes are together, all I can think is to check the fluid on the pump and if its OK then maybe bleed the brakes off at each wheel??
Old Dec 20, 2010 | 06:11 PM
wyoranch's Avatar
Yeah, the fluid level is fine. And the brakes work Great, just don't release. And man it whines when you try to turn the wheel!
Old Dec 20, 2010 | 06:16 PM
Red_Rattler's Avatar
High Tech Redneck
Ps pump is most likely the culpurate. Have fun changing it it's def a treat. Done 2 of them now...
Old Dec 21, 2010 | 11:29 AM
wyoranch's Avatar
But would the brakes still have plenty if power if it was out? They grab great, just don't release.
Well, started it up this morning in hopes that it had fixed itself. When I started it up the power steering and brakes seemed normal. After a minute or so it went back to the same thing
Old Dec 21, 2010 | 12:24 PM
steved's Avatar
I would suspect a faulty hydroboost...
Old Dec 21, 2010 | 01:50 PM
wyoranch's Avatar
Ugh. I hate throwing parts at it. Any way to test the hydroboost or powersteering pump to see which one it is?
Old Dec 21, 2010 | 01:56 PM
steved's Avatar
Process of elimination...follow me here:
Considering the PS and Hydroboost (Brakes) both require pressure from the pump to operate, and only ONE of those two systems (the PS) is operating normally. Add to that the fact that the Hydroboost controls the brakes (the part your having issues with), but not the PS (directly anyway); my vote is the Hydroboost. The fact the PS is working sort of rules out the PS pump...
Old Dec 21, 2010 | 02:06 PM
wyoranch's Avatar
I may have not explained it right. The power steering is not working. The brakes seem to have good power, but when you let your foot off the brake pedal the pedal stays down. The brakes are still grabbing. You have to pull the pedal up to go again
Chris Herron
Sep 2, 2015 08:02 PM
4estlee
Oct 7, 2014 07:47 PM
