help with 05 ford 6.0 ltr,please!
am running a 05 6.0 ltr ,I know there not the best by far,but anyhelp here would really be appreciatted.Here is a bit of history on this engine,had the ficm changed 3 mths ago,had hpo chaged 2 ths ago,and then the other day was running fine ,then came to pull away from a store and blue smoke and severe miss started,got it home and put some fuel conditioner,cleaner in and changed oil,it starts right up when u crank,but after a few minits it starts to smoke blue,and after its warmed up it clears up with no smoke,when driving it goes in to limp mode were it will only go 90-95 kmh,no matter how hard you push on the thottle,other than that it seems to run and idle not to bad,but I can tell there is a miss.Long story short,took it to dealer and they say I need a new motor!!!,they say low compression on #1,3,and 5 and #7 is overfueling.But there is no blowby from the oil filler tube and it ran great up till yesterday,please help!,I am ready for a nervous breakdown here.
ok,,but would a blown head gasket not pressure up the coolant?
just got a call from dealler,,now they are saying it could be bad valves??,they done a crankcase pressure test and its not to bad,I personally think its just injectors,but don't want to spend 5 grand for nothing
Last edited by harley_2010; Dec 20, 2010 at 02:03 PM. Reason: Automerged Doublepost
I'd double check the FICM. A lot of times you'll see this exact issue, a whole bank of cylinders is "bad".... notice the 1,3,5,7... If it was 4 random cylinder OK, but it's not, it's all on one side. I'd test the FICM. It may or may not be the issue, but it's easy to test and free.
Where are you located?
rings...sorry man
