Misses under hard acceleration. WHY? Ideas?
Old Dec 19, 2010 | 10:17 PM
trucken's Avatar
Default Misses under hard acceleration. WHY? Ideas?
Just did head gasket and studs. After assembly i turned up the tune a little. Jumped on it a bit, got a bop, bop, bop kinda miss. Or maybe its a pop, pop, kinda miss. Idles fine, runs fine under light pedal too. Only misses when I hit it.
Only thing I can think of is valve lash was a little loose (I notice while re-assembling) Figured I adjust valves later after running a while.
Any Ideas?
A look below will show the mods.
Old Dec 20, 2010 | 12:12 AM
Youngblood's Avatar
my friends 01 did this and he had all new valves and valve springs done and has never had a problem since, his truck also had 210k on it, so I don't know
Old Dec 20, 2010 | 12:53 AM
Red_Rattler's Avatar
High Tech Redneck
Def could be some float going on. Why would you wait to adjust them?! Good way to screw a motor up...
Old Dec 20, 2010 | 01:05 AM
prison's Avatar
you were in there anyway man ya should've at least checked them. preventative maintenance. This'll teach ya. it's much better than killin a motor but next time take your time and check everything
Old Dec 20, 2010 | 01:40 AM
Rustin's Avatar
How is the LPG working for you?
Old Dec 20, 2010 | 07:51 AM
trucken's Avatar
Default Got 250,000 miles on it.
The LPG is lame. about 40 hp around town. I never use it while racing, nitrous IS the way to go. 300 hp instead. LPG was a waste of money. But I keep it. Now putting methonol injection on. After I fix valve miss, if thats what it is.
That job was a pain in the ***. had to pull off both turbos, 2nd CP3, Exhaust manifold bolts are killers to get to.
I assume the gasket I pull off was factory. The new gasket I put on was OEM cummins. Maybe new gasket was a few thousandths fatter, giving me more lash.
It was a 5 layer gasket that cummins uses. I dont know. I'll try adj valves first. I had an idea they were a little loose when I re-assembled. BUT LIke I said, its an easy adj, compared to R&R head gasket.
What can I say, $ was an issue, I joined the other 10% of america, unemployed due to the oil spill in the GULF. Drill-Ban.
Old Feb 27, 2011 | 08:56 PM
trucken's Avatar
It was an injector issue. 2 bad ones. Probaly 1 then, then continued use fried another.
Don't use RAIL plug! Keep the modified relief valve installed.
Old Feb 27, 2011 | 09:46 PM
mysterync's Avatar
Rail plugs are for diagnoses only
Old Mar 1, 2011 | 04:01 PM
cerberus60's Avatar
Typical with a Smarty on the 555's. Start playing with the tunes and timing to find one that will work well.
cramage28
Sep 20, 2015 11:37 AM
corksil
Aug 2, 2015 10:19 PM
OBSBEN
Dec 31, 2014 11:35 AM
UC Kid
Oct 20, 2014 10:06 AM
