pickup running rough.
Old Dec 19, 2010 | 02:24 PM
zach_west's Avatar
Default pickup running rough.
I replaced my injectors in my 03 and when I got them installed the pickup started idling rough. It didnt do that before I replaced them. it's putting out a haze of white smoke at idle and puffs it when revved up. I thought maybe it was air in the system but i ran it for about 10 minutes and it never cleared up. I checked my lift pump and there wasn't any fuel out of it so I replaced my lift pump with an airdog 150(mainly because I wanted to go bigger). I'm not getting power to it though. I'm throwing a P0483 fan speed code I ran continuity tests through the injector harness and everything checked out ok. The injectors are reman injectors from taylor diesel out of amarillo. I load tested my batteries and they checked out good 2. My battery cables are in good shape. if you try to drive it it goes about 1/2 a mile and dies. I think there's an electrical problem but I can't find it anywhere. My scantool shows no codes either so i think the fan speed code is a ghost code. I really need some help or ideas on this one. Also no diesel in the engine oil.
Old Dec 24, 2010 | 06:11 PM
Black Smoke Mafia's Avatar
Well white smoke is raw fuel plain and simple, this is usually a sign of bad injectors. I'd venture to say that A: you got a bad batch of injectors, B: They may have damaged something installing the injectors and/or installed them incorrectly C: Like you stated there is something wrong electrically. or finally D: My best guess would be that the Airdog isn't working (that could go back to your electrical problem) and your choking it off.
Old Dec 24, 2010 | 06:40 PM
zach_west's Avatar
ok got my pickup evened out the guy that gave me the valve lashes was wrong. he said 7 and 13 and its 10 and 20 so ya. I have a new problem now. The pickup acts like it starving for fuel if you get on it at all it acts like it's running out of diesel. the airdogs assembled right i put the drawstraw at the rear of the fuel tank is that wrong?
Old Dec 24, 2010 | 07:01 PM
did the injector pump get damaged?
Old Dec 25, 2010 | 11:21 AM
zach_west's Avatar
it shouldn't have it was running right before and i never touched the ip. it feels like it's pulling air though a little bit. I put a full tank in and got all over it and it didnt do it until i got to 3 grand started sputtering a little bit. but when i have it anything less than half a tank i have to barely touch the throttle or it starts sputtering and almost dies.
Old Dec 25, 2010 | 11:45 AM
must be sucking air through your draw straw?
Old Dec 25, 2010 | 12:26 PM
zach_west's Avatar
maybe idk see how there's no hole in the draw straw anywhere. after my fuel level goes down a bit i'll drop the tank and redo it. probably put it more in the middle of the tank.
ssmith.77
Nov 25, 2018 06:56 AM
ssmith.77
Jan 11, 2015 02:03 PM
f250white
Jan 11, 2015 09:25 AM
Fishy816
Jan 11, 2015 08:31 AM
bizurkhate
11
Nov 14, 2014 12:15 AM
