surging,jerking
Old Dec 18, 2010 | 09:06 PM
cummins-dodge's Avatar
Default surging,jerking
when i start do accelerate hard the truck starts surging or jerking like the motor is missing with the edge box on 6 but if i turn it off it does not do it it is the quad cab truck the first one in my sig.
01 dodge quad cab 5spd 275000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, schied lighting pump, .093 connector tubes, ats head studs, 300 hp injectors, s400 turbo and s300 twins, custom billet intake plate, cooling mist water meth injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, south bend upgrade hydulics, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valair on board air with Siberian express train horns,
pulling stats.
hanks 4x4 3rd 282.56ft
01 dodge reg cab 5spd 275000 miles cold air intake afe, cooler tubz, single electric fan or i can put the stock clutch fan on, air dog 150 new 1 month old, stainless steal nerf bars, edge juice att. hot unlock, .093 connector tubes, valair single disc clutch, 4inch from turbo to duel 5 inch miter stacks, leveling kit, American racing wheels, 33x12.50x16.5 bfg's, ranch hand front and rear bumpers for sale
84 chevy k30 reg cab with 94 12v p pump cummins and nv4500 trans 205 transfer case 3 inch body lift, 6 inch suspension lift, 36x14.5x16.5 parnelli jones dirt grips, 16.5x12 weld scorpio wheels, dana 60 front, duramax rear axle, duramax intercooler, schied custom injection pump, 370 injectors that are extude honed bigger, o- ringed and head stud, marine lift pump, custom ground cam, cooling mist water meth. injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, valair hydulic upgrade, industrial injection silver bullet 66 turbo, no fuel plate, single 5 inch miter cut stack
pulling stats
hanks 4x4 7th 256ft
92’ regular cab long-bed dodge power ram d250 Cummins automatic 4x4 truck. The truck has 220,000 miles on it, and 20,000 miles on the motor, and transmission.. The rebuilt motor has new pistons, bearings, crank, rods. The rebuilt transmission has new clutches, new overdrive gear, and new torque converter. The transfercase has new bearings in it and was done when the motor and trans was. The truck also has a new radiator, new red top optima battery, new starter, new rebuilt injection pump when motor was done, just turned up the pump and put a custom ground fuel pin in it, new steering box, new drag link, fresh gas tank straps, boost gauge, and 2 gauge-gauge pod, a two sizes bigger hx40 turbo, 5inch miter cut chrome stack, also has a dmi bumper and stock rear bumper with a newer reese hitch, new drivers door window switch, power locks, and a set of tires with 80% tread left that come with it also. Truck only needs upper balljoint on passenger side and the brakes bled, brakes work you just need to pump the pedal FOR SALE
03 honda rincon 650 1500 miles with 2 inch lift, 27 mudzillas, 1 1/2” rear wheel spacers, 1 inch front wheels spacers, hmf pipe, dynatek cdi, dynatek coil, k&n air filter, rejeted 170 main , spring clipped 8 coils, 5000 lb winch, heated grips, 14% gear reduction, 2 inch snorkel
95 yamaha warrior 350 bored out to 366, stage 2 hot cam, JE 85mm piston 12.5:1 compression, new rod, k&n air filter, white bros. pipe, bigger coil, performance cdi box, nerf bars, oil cooler mod, full skid plates, heavy duty racing clutch, jetted
07 Kawasaki klx250 on offroad bike moose air filter, fmf pipe mostly stock
Old Dec 18, 2010 | 09:09 PM
prison's Avatar
sounds like either your airdog is dying or you're ip is dying. btw that sig is long
Old Dec 18, 2010 | 09:12 PM
H.R.D's Avatar
I'm willing to bet its the edge jacking up on you. Mine did that for a while then it went completely hay wire. I would send it back to edge and have them check it out.
Old Dec 18, 2010 | 09:19 PM
prison's Avatar
Originally Posted by H.R.D
I willing to bet its the edge jacking up on you. Mine did that for a while then it went completely hay wire. I would send it back to edge and have them check it out.
also a definite possibility. what is with these edge's it seems like a lot of people are having problems with them
Old Dec 19, 2010 | 11:58 AM
cumminsman315's Avatar
check your fuse in the fuse box under the hood, where the edge power wire taps too
yesterday i had a guy come in that was doin something very similar to what you described, and the problem was the fuse would move after he hit a bump and start surging, never had one do that before..his problem felt like you fell of the pedal then when it picked back up it would jerk forward hard enough to move your foot and do it over and over
so i chopped a little plastic out of the holder so the fuse jumper still lets the fuse sit tight and good as new
Old Dec 19, 2010 | 05:53 PM
my airdog is holding at 17-20 psi and is a little over a year old and it didnt do it untill i put the bigger injectors in and it has gotten worse since it has gotten cold could it be that the injectors are so big and the fuel and timming that the edge box is putting to it the pump cant keep up because when i turn the box to 0 it dont do it so would a bigger pump fix the problem
01 dodge quad cab 5spd 275000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, schied lighting pump, .093 connector tubes, ats head studs, 300 hp injector, s400 turbo and s300 twins, custom billet intake plate, cooling mist water meth injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, south bend upgrade hydulics, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valair on board air with Siberian express train horns,
pulling stats.
pulling stats
hanks 4x4 7th 256ft
Old Dec 20, 2010 | 07:08 AM
ironhead79's Avatar
Default jerking / surging.....
Mine does the exact same thing, are you getting any codes?
Old Dec 20, 2010 | 08:08 PM
no i have not check for any codes yet
Old Dec 20, 2010 | 08:48 PM
Rustin's Avatar
Hmmm... Sounds like you not getting the fuel like you need. The Edge is wanting to add fuel, and the Trucks system is fighting it. Find out if you have any codes if not I would send the Edge in. Those things are starting to create problems. Hmmm.... I think I mentioned this in the beginning of the year. Or last year before the first ban.
Old Dec 20, 2010 | 09:30 PM
Whit's Avatar
Site Mascot
I would say fuel delivery myself
