P0628 code
Old Dec 18, 2010 | 05:52 PM
dyanz's Avatar
Default P0628 code
Suggestions on P0628 on replacing lift pump or installing in tank pump. What are the pros and cons to replace existing pump by fuel filter or to put it in the tank? Cost and ease to do this what do you think???
Also, should I check relay voltage to see if relay could be the problem? What should the voltage read?
If so where is the relay located on dodge 2004 5.9 L diesel engine?
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
