cummins wont run right
Old Dec 18, 2010 | 04:39 PM
12valvecory's Avatar
Default cummins wont run right
i just got my rotary pump cummins running and now it has a lope to it at low idle and if you rev up the motor it goes awaybut then when you let it back down it goes back to loping and sometimes dieing.
Old Dec 18, 2010 | 06:56 PM
901stgen's Avatar
Check your fuel screw and your idle screw.
Old Dec 20, 2010 | 11:24 AM
Mark Nixon's Avatar
There is dirt or air somewhere.
With it idling, CAREFULLY loosen and re-tighten each injector line at the injector.
You're looking for one that doesn't react, or that clears up the miss when you re-tighten it.
Normally if things are right, loosening the line will release fuel pressure and cause it to miss, tightening it back up will make it go away.
If you isolate which injector it is and it won't clear up, you can assume it's a fuel delivery issue.
Sometimes low lift pump pressure, or a supply leak, can areate the fuel and cause it to miss.
Mark.
Old Dec 21, 2010 | 02:52 AM
blazier18's Avatar
wats rpm idling at lopin or not
Old Dec 27, 2010 | 12:08 AM
cumminskid92's Avatar
my truck did the samething and my problem was the gov. in the pump. i had the pump rebuilt and the truck runs great now.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
vin_diesel
Mar 1, 2016 01:43 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
