lose of antifreeze
Old Dec 18, 2010 | 09:53 AM
96blackcloud's Avatar
Default lose of antifreeze
have to work on our 6.5 stake bed at work, its eating antifreeze somewhere. its not dripping or leaking, its not in the oil so my guess is its burning it via head gasket is there any other places i should look before compression checking the heads
Old Dec 18, 2010 | 11:32 AM
Crazy's Avatar
sound like you call it right head gasket just remember if is head gasket sure you go with ARP studs for head bolts
i should ask what yr truck is it but place do leak and can't see very good it at heater hose at t-stat it has one them snap in fittings
Old Dec 18, 2010 | 04:03 PM
mud's Avatar
mud
Thats were mine leaked at plastic fitting at tstat i guess only when i was driving didnt see it at idle. i needed truck got one for a gasser n it fit ?
Old Dec 19, 2010 | 09:40 PM
its a 94 i do believe its just a work truck so it will not be getting studs of any sort i figured the worst being its a head gasket its only got 140k on it but ill check that fitting thanks guys
Old Dec 19, 2010 | 09:52 PM
Crazy's Avatar
if you are burning coolant you would have lot white smoke coming out exhaust and they say that some time you don't see the coolant in oil run die throw in coolant and use black light if it in the oil the black light will pick it on the dip stick
jorttel
Feb 22, 2015 09:50 PM
tumble72
Nov 20, 2014 12:31 AM
