What injectors,programmer,turbo how does it smoke and how about the egt?
Old Dec 17, 2010 | 07:05 PM
blowin smoke 1's Avatar
bulb What injectors,programmer,turbo how does it smoke and how about the egt?
Just seeing what everyone is running on their trucks.Do yall like the way they run?How much egt?Can you change the weather forecast from a redlight?Looking for differnt combos and see how it runs.Thought it would be cool to see.
Old Dec 17, 2010 | 07:26 PM
Farmboy 2.0's Avatar
Edge juice w/ attitude, 6x18 Industrial Injections Super Dragon Flows, BHAF, AD2 165, 62mm turbo which is to small, BD exhaust manifold and some other junk. I think it smokes alil too much and it runs decent on egts because of the nice injectors
Old Dec 17, 2010 | 08:26 PM
Cool vid mine ran bad with the 150s after I replaced the head gasket ddp told me it was to much fuel that poped the head gasket.I am still thinking about that being it only hit 1350 max egt just fluttered the turbo almost like a mis.took them out put 50s in had them checked they were on the money.Beginning to wonder about my pump being that I can airlock it easily.I am running out of ideas?
Old Dec 18, 2010 | 12:55 AM
Thanks we couldnt get the dyno to load it hard enough so i was only making 30 psi boost so it was super smokey!!! I shoulda won the smoke show . What do you have as a lift pump? And a bigger turbo and manifold would help get some restriction outta your engine.
Old Dec 18, 2010 | 06:13 PM
connermcpherson's Avatar
DDP 150'S 175 p pump .120 lines, tubes, and feeders 66/74/14 silver bullet. can black out both sides of a six lane road til the turbo lights. egts at wot about 1450-1500. runs like a savage and gets good mileage
Old Dec 18, 2010 | 09:30 PM
Cool maybe I should have a 66.
Old Dec 19, 2010 | 07:59 AM
turbo20psi's Avatar
64/71/14.Fireball 150's,Cam,Smarty and Edge comp,Edge makes more power on dyno,Smarty better gas mileage 20mpg with 410'S,Max EGT's 1300 degrees. 4 inch S.S. exhaust,ATS intake.
Old Dec 19, 2010 | 09:21 AM
i really like my 66 but u gotta have the fuel to spool it, im seeing 55-60lb boost
Old Dec 19, 2010 | 06:26 PM
I see 53 with my bd single and 50hp injectors quad v2 on 10 and 1375egt today going to try the 150s and the bd special this week.Its cool to see what yall are running to know what works.Thanks
Old Dec 21, 2010 | 08:36 PM
Lookin for more posts come on guys help a bomber out
