MY TURBO
Old Dec 17, 2010 | 05:51 PM
ADRIAN's Avatar
Default MY TURBO
HAY IF ANYBODY CAN HELP OR HAVE SOME TIPS:IM TRIEN TO OPEN THE WASTE GATE UP ON MY TRUCK TO GET MORE POWER. ITS A 96 DODGE 3500: IT HAS THE 5.9 6C ENGINE: IT ALSO HAS A 5 SPEED MA: RIGHT NOW IM AT ABOUT 7LB OF BOOST AN I WANT MORE IS THERE A WAY
Old Dec 17, 2010 | 05:57 PM
Flight911's Avatar
Yeah the line comming from the AFC housing to the wast gate on the turbo.. either pinch that rubber line or do what i did and cut the hose and plug it up with a bolt or something.
then take your fuel plate out and you will see a major power increase
Old Dec 17, 2010 | 06:07 PM
ADRIAN's Avatar
OK ONE MORE THING WILL THIS AFFECT ANYTHING ELSE
Old Dec 17, 2010 | 06:21 PM
Flight911's Avatar
Nope. Then if you really wanna c a difference either slide your fuel plate forward or take it out like i did. BUT.. Some guys will argue that if you take the fuel plate out it might do a run away. I disagree cause mine has never did that. Theres more you can do but you run into the risk of to much boosting your stock turbo and messing it up
just go out there with a pair of vice grips and pinch that hose comming off of your turbo and tell me if you see a difference.
ADRIAN's Avatar
OK ILL TRI THAT BUT I DNT NEED A RUNAWAY AN THANK U
Old Dec 18, 2010 | 03:55 AM
97cummins's Avatar
taking out the fuel plate also increases the fuel,which increases the egt's. i'd recomend guages first.
Old Dec 18, 2010 | 05:07 PM
ADRIAN's Avatar
I PINCHED THE LINE AN THE TURBO SPOOL FASTER AN WAS LONDER BUT DID NOT TAKE THE PLATE OFF YET
Old Dec 19, 2010 | 12:04 AM
crusty_critter03's Avatar
dear newbie... all caps??? feels like your yellin at us fella... haha
and i second 97cummins last post... plug the wastegate an you 'should' be fine. just watch doin to much tinkerin with your fueling before AT LEAST egt an boost gauge install...
Old Dec 19, 2010 | 02:10 AM
cumminsp12v's Avatar
your only gettin 7lbs of boost? i can hit that just goin up a hill with the cruise set haha. i can easily get over 30lbs
Old Dec 20, 2010 | 10:38 PM
oldturbonut's Avatar
Default turbo boost
Check this boost vs back pressure vid on youtube
YouTube - turbo boost vs back pressure
