tranny good but not shifting help!!!
Old Dec 17, 2010 | 03:30 PM
green thang's Avatar
Default tranny good but not shifting help!!!
ok so i had the tranny rebuilt 3 months ago and then last week it started to act up again skipping gears and shifting all over. so took it to the tranny place they put in a new valve body and they said it still didnt shift right so they put in some new sensor on the rear axle that senses speed still nothin. they finally said they cant do any more they dont know. so i called ford and they said it might be the guage cluster. this makes a little sense seeijnt the spedo reads way off (on the highway it says im doing 30-40 mph), the oil pressure guage is at low (not cuz the truck still runs fine not ticking or anything) and the coolent guage reads cold long after warm up (though it never really has woked right to begin with)
i need suggestions please help!!!!!
i think i might start looking at the sedo cable to see it thats broke then what?
Last edited by green thang; Dec 17, 2010 at 03:30 PM. Reason: Automerged Doublepost
Old Dec 17, 2010 | 04:20 PM
DieselCrawler's Avatar
cant help ya here. never had an auto in my fords.
Old Dec 17, 2010 | 05:46 PM
ya lookin back i should have never gotten a auto nothin ut trouble i gotta keep lookin around for answer
Old Dec 17, 2010 | 06:00 PM
tiremann9669's Avatar
I have a buddy that had a 94 and he chased similar problems for over a year before they figured out it was the wiring goin to the trans. Wiring looked fine lookin at it but when cut open it was all coroded green and it literally disentegrated. Only thin I can figure is over the years the insulation on the wire cracks or becomes porous. Worth checkin it out I guess.
Old Dec 17, 2010 | 07:26 PM
i do know the sensor on the injection pump does need to be properly set for shifts to be correct. not sure how to do this though.
Old Dec 17, 2010 | 11:22 PM
there is a sensor on the ip? the tach sensor?
Old Dec 18, 2010 | 10:37 AM
css89's Avatar
Default transmission shop
I would most likely suspect the actual rebuild if they put in a new valve body after wards for you they didn't do much of a job to start with and they certainly should know how to set every thing up including sensors and cables.
Last edited by css89; Dec 18, 2010 at 10:39 AM. Reason: on my old 6.2 chevy diesil theres a cable that goes to transmission and if it's not set right tranny will not shift properly
Old Dec 18, 2010 | 02:10 PM
well did some reserch and sounds like the vss which i guess is on the rear pumpkin on top. thats a new sensor or can be the wireing to it. also waas reading whats a tone ring? the reading said that might be bad. any thoughts?
i just checked the rear vss on the rear diff. the wireing looks fine so does the sensor itsself brand new the shop put it in 2 days ago.
just got back from test drive the rear abs light still on (has been for about 4 months) and still not shifting right. suggestions?
Last edited by green thang; Dec 18, 2010 at 02:10 PM. Reason: Automerged Doublepost
Old Dec 18, 2010 | 09:57 PM
tone ring is inside the diff. it is what the vss gets signal from.
Old Dec 19, 2010 | 09:27 AM
ok i looked inside the rear diff and saw the tone ring it looks fine all i can think of is replacing all the wireing even though it looks ok. im starting to get really pissed off with this thing.
