2004 cummins won't start
Old Dec 17, 2010 | 03:10 PM
dyanz's Avatar
Default 2004 cummins won't start
5.9 diesel can't get it to start. This is my first diesel so a lot is new to me. Checked fuel filter and it seems to fill fuel back up after bleeding some out. Cranks but won't start. Live in war m climate. Suggestion on what to check?
Old Dec 17, 2010 | 03:17 PM
dryodt's Avatar
Any smoke when cranking?
Old Dec 17, 2010 | 03:59 PM
H.R.D's Avatar
It could be the afc (actuated fuel control) on the cp3 or the CSS (cam shaft sensor). I would check for codes with a reader or the key trick.
Old Dec 17, 2010 | 04:45 PM
dyanz's Avatar
No smoke
Ok,
What is the key trick?
Old Dec 17, 2010 | 05:10 PM
H.R.D's Avatar
The key trick is to turn the key to the ON position and back off 2 times, on the 3rd time leave it in the ON position and codes if any will read out in the odometer. DO NOT start the truck.
Old Dec 17, 2010 | 07:21 PM
dyanz's Avatar
Default key trick
I'll try that in the morning. Thanks for your suggestions. More info on truck. 2500 5.9 L engine. Can the fuel shut off solenoid keep the vehicle from starting? We checked the fuel filter and drained some diesel off then tried starting it and the fuel canister filled up so we think we are eliminating the fuel pumps? This engine just turned 105 K.
ronstop
Feb 26, 2015 09:48 AM
mcclusk
Feb 21, 2015 09:50 PM
HKLBRY
Feb 18, 2015 09:46 PM
HKLBRY
Feb 17, 2015 08:52 PM
Downd19
Dec 30, 2014 02:49 PM
