96 cummins 12v turbo upgrade
Old Dec 17, 2010 | 04:12 PM
Flight911's Avatar
Default 96 cummins 12v turbo upgrade
Alrite you know it all's out there need some good input for a good turbo upgrade. I got a 96 cummins 12v. I took the fuel plate out, did some mods to the AFC housing which i don's think matters since a took the plate out, i also put a 2095 mack rack plug and took a die grinder and cut the foot feeding stop bolt off. That makes a hell of a difference cause now i can rev 3,500 rpm or close to floating valves. Anyways i had the stock turbo boosting 40psi with the waste gate pinched off, needless to say my turbo didn't last long. Question is, what is a good turbo ungrade to get that will allow me room to grow in the future? Maybe a single that will work with twins later on? The more info the better. Thanks
Anybody????
Old Dec 17, 2010 | 04:17 PM
moneyman_09's Avatar
s300 id say62/65/12
Old Dec 17, 2010 | 04:27 PM
Flight911's Avatar
How much does one of them cost
Old Dec 17, 2010 | 04:49 PM
Depends on where you get it from i'd have to say from $500-$1500
Old Dec 17, 2010 | 04:53 PM
12vcummins96's Avatar
a 64/71 14
is a better canadate but about 1800 bucks new
Old Dec 17, 2010 | 04:59 PM
cummins freak's Avatar
for twins what are your goals towing or jsut big numbers?
for towing I say a 62/68-71/14 would be a good single to grow into and to make a really hard spooling set of twins if paired with say an s475-480. shoud make good streetability because you wont have the lag of a bigger turbo down low like a 64/71/14 if towing or pulling.
now for an all out big numbers TOY BD-special over s480 and hold on when IT all lights
Old Dec 17, 2010 | 05:32 PM
Flight911's Avatar
64/71/14?? Is that 64mm intake side 71mm exphast side and 12cm?
Man its a ton1 dually. I dont tow anything with. For time to time i might put 10,000lbs behind for a short distance. I wont 700rwhp. For as little as i did to it a freak of nature cause i can roll some coals and i burned up a stage two clutch. I have alittle money to spend. I just dont want to get something and be pissed off when i get on in. Over....
Yeah see i glad you said BD special cause i been looking around and i keep leaning towards it
Old Dec 17, 2010 | 07:41 PM
the BD special was one I really wanted for my modded 12v but I got the deal i wanted on my 64/71/14 by HTT so I took that instead. The special is said to be the best single for a modded 12v thats a power toy
Old Dec 19, 2010 | 11:14 PM
95 12v's Avatar
i just got a silver bullet 66 and i love it ! great all around turbo! to me but everyone likes there own things idk how it well it would be with a compound set up up but as a single its sweet
Old Dec 22, 2010 | 04:00 AM
c12vpwr's Avatar
i did the same thing u did with my stock turbo and i wanted a good turbo that i could make to twins in the future and i put a ats aurora 3000 on my truck witch has been a good turbo and is easy to throw a 5000 behind it now it dose cost about 3000 dollars for a hole kit but has a great warranty and also if u get this turbo u may want to buy injectors to spull faster
huntman7
8
Aug 28, 2015 05:42 PM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
Jan 28, 2015 03:30 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
