changed batteries
Old Dec 16, 2010 | 07:18 PM
little john's Avatar
Default changed batteries
changed batteries in 03 dodge with 5.9 cummins ran about 15 miles shut off for the night now will not start turns over a little slow even though block heater is plugged in
Old Dec 16, 2010 | 07:26 PM
kazairl's Avatar
Did you change the batteries because it was turning over slow? Did you check to see if you had a drain on the system?
Old Dec 16, 2010 | 07:48 PM
Default batteries
changed because was cranking slow and hard to start put new ones in ran fine now won't start just had ice storm and havent had time to chech further
Old Dec 24, 2010 | 01:57 AM
dangerous1965's Avatar
clean the cable terminals really good. What are the CCA of the new Batteries? SaME as the old ones? Check all your connections "grounds"
Josh Gordon
Jul 2, 2015 07:40 PM
greasesheik
Apr 9, 2015 09:33 PM
willgoss
Ford Powerstroke 08-10 6.4L
Feb 12, 2015 09:52 PM
mpcampers
Dec 4, 2014 08:24 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
