code 2509
Old Dec 16, 2010 | 01:47 PM
tatt100's Avatar
Default code 2509
new to site , new to diesel trucks , i have a 06 2500 with 5.9 24 valve . sometimes truck stalls as if you turn key off starts right back up and runs fine , but, has code 2509 took it to the dealer and they said its the fan clutch. is this possible ? sorry but gotta learn about these things somehow not even sure if i posted this properly
Old Dec 17, 2010 | 02:47 AM
dontneedtostroke's Avatar
P2509- ECM/PCM Power Input Signal Intermittent
POOR CONNECTIONS AT THE BATTERIES
LOW BATTERY VOLTAGE
OPEN FUSED B+ TO ECM
OPEN GROUND CIRCUIT
BATTERY + SHORTED TO OTHER CIRCUITS
RETURN CIRCUIT SHORTED
BATTERY + SHORTED TO GROUND
INTERMITTENT CONDITION
p2509
click that and read the second post. should explain it fairly well.
is that the only code you got? Did you recently add a box/programmer?
Old Dec 17, 2010 | 07:33 AM
tatt100's Avatar
that is the only code , replaced batteries, checked and cleaned all grounds, the strange part it is that it only does it when is cold .ambient temp has been about 20 degrees yesterday it cycled the grid heater 13 times. it don't do it every time and gives no warning. it dont matter if i plug it in or not . truck only has 35000 miles still like new
dwmeehan
Sep 6, 2015 04:20 PM
1ATony
1A Auto Parts
Aug 3, 2015 10:35 AM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
