HELP PLEASE!
Old Dec 16, 2010 | 08:26 AM
SCOTT ELZEY's Avatar
Default Truck runs rough
My truck starts but breaks down under a load . Like 1 or 2 cylinders are not happening the engine runs rough. changed fuel heater. what about the injecters/ Fuel is fine . installed lift pump last 6 months.also the injector pump. trucks got 250 thou miles.
Old Dec 16, 2010 | 08:48 AM
mishkaya's Avatar
Do you have a fuel pressure gauge?
Sounds like you are not getting enough fuel to the pump...
Did you check for codes in the odometer window?
Old Dec 16, 2010 | 08:56 AM
no fuel gauge . no codes. is there a diffrent gauge for diesel
or is the fuel gauge for gas ok
Last edited by SCOTT ELZEY; Dec 16, 2010 at 08:56 AM. Reason: Automerged Doublepost
Old Dec 16, 2010 | 08:57 AM
stodg73's Avatar
What is your fuel pressure? How much of a load? bed loaded, pulling a trailer, etc. What mods have you done??
It could be your APPS, the VP, a bad ground, another bad lift pump, etc.
Old Dec 16, 2010 | 09:01 AM
mishkaya's Avatar
On a 24 valve Cummins with a VP44 injection pump, it is imperative to have a fuel pressure gauge. Lack of fuel supply to the injection pump is disastrous as it depends on the fuel for cooling and lubrication. My guess is lack of fuel pressure at this point. You can get a cheap fuel pressure gauge at Autozone or the likes for initial testing, but I would highly recommend getting an in-cab pressure gauge so you can monitor pressure at all times.
Where are you located? Could it be a gelling issue?
Old Dec 16, 2010 | 09:04 AM
thank yall so much. sounds like i need a fuel gauge. will a gas fuel gauge work?
Old Dec 16, 2010 | 09:10 AM
stodg73's Avatar
You need a fuel pressure gauge. A cheap one from Harbor Freight/Autozone will work. A "Fuel injection pump tester" from Harbor Freight will attach to the schraeder valve on the injection pump to see how much pressure you have.
mishkaya's Avatar
I would recommend getting either an Autometer or ISSPRO gauge. If you use either an electric gauge or an isolator, it won't matter much which type you have. You need a gauge that will read up to 30 PSI ideally.
You can purchase a gauge directly from one of the vendors on this site, they are helpful and reasonably priced. All you need to do is request a price quote here:
https://www.dieselbombers.com/price-...request-price/
They will set you up with everything you would need for the install.
Old Dec 16, 2010 | 10:11 AM
dieseldoc.'s Avatar
the best way to find out if injectors are shot,crank truck,crack #1 fuel line,if the motor starts missing and laggy tighten it back its good.keep doen this an when you come to a line that you cracked loose an the motor has no changes an it is missing like its been,then the injector is bad,do all six,an replace all six when you do.
