Buzzing sound under hood 99 dodge
Old Dec 15, 2010 | 05:41 AM
Blacksmoke Bulldog's Avatar
Default Buzzing sound under hood 99 dodge
My Dad and brother have a 99 dodge that is buzzing in the fuse box underneath the hood. The engine will turn over but will not fire. It acts as if it is not getting fuel to the VP44. Any ideas or suggestions?
Old Dec 15, 2010 | 07:26 AM
RAW's Avatar
RAW
I'd say pull the cover off the fuse box and see whats making noise. There are a few relays in there, if one is clicking or buzzing swap it out with another one.
Old Dec 15, 2010 | 09:54 AM
They already did that and swapped out the ads relay reset computer or flashed it and there was no change.
Old Dec 15, 2010 | 10:05 AM
RAW's Avatar
RAW
I can't think of anything that would buzz in the fuse box. How about grounds? Power into the fuse box connections? Its not a fuel pump on the block buzzing?
Old Dec 15, 2010 | 11:03 AM
I dont know they are in Colorado and i am in Texas. It is hard to completely diagnose something over the phone.LOL
Hey, Rawilliams does your edge surge a bit when really loading it down. I have plenty of power but it is a bit jerky when climbing a hill with a load. Real quick like it is shorting out and then coming back.
Last edited by Blacksmoke Bulldog; Dec 15, 2010 at 11:03 AM. Reason: Automerged Doublepost
Old Dec 16, 2010 | 06:41 PM
Mrfatsac789's Avatar
I was just readingsomething about a guy who has a buzzing coming from under his dash and everyone thinks it's a problem with his fuel pump...
Old Dec 16, 2010 | 06:46 PM
RAW's Avatar
RAW
Only when I'm pulling hard, REAL hard. Surges between 57 and 54 psi boost, and I can feel it in the truck. Definately a fuel issue.
Old Dec 22, 2010 | 08:41 AM
You get 54 to 57 psi of Boost? I only get about 37 max. I have a fass fuel system and the gauge never goes below 10 psi when feeding the VP44. When i put the edge on stock the surging stops.
Old Dec 22, 2010 | 09:26 AM
biged681985's Avatar
he is running twins. the buzzing sounds like the lift pump on the side of the block, and if its running when ur trying to start it, it could be putting it in a hard start situation. if there sure it aint coming from any lower, than the fuse box, it may also be coming from the ABS block right next to the fuse box. the ABS system on my green truck never worked since i got it, it was missing the relay for it. nticed it one day, and plugged it in, and it buzzed like a SOB so i pulled it and just run it with out ABS. but that wouldnt cause it not to start. good luck getting it figured out
Old Dec 22, 2010 | 09:41 AM
RAW's Avatar
RAW
With returning to 0 on the Edge it may be a connection issue or a problem with the Edge itself.
I have a compound turbo system that has really increased my boost. I used to make 37 PSI MAX, and it put my HX35 to its limits.
