Egt probe?
Best option is in the drivers side manifold on the 6.0, pre-turbo. You want the numbers on your gauge to closely represent the cylinder temps as much as possible.
Also make sure you don't put it right in line with an exhaust port, try to put it in the elbow of the manifold where it starts heading towards the up-pipes. It's pretty easy to do if you crawl under the truck.
I think that is where I'll put it I'll have the motor running while drilling that way the pressure will blow out the shavings.
Brappp306
Mar 29, 2015 08:54 PM
CumminsCoalRoller24/7
Jan 29, 2015 08:37 AM
offroad00
24
Oct 23, 2014 03:28 PM
