oil in coolant on 97 5.9 cummins
Old Dec 14, 2010 | 04:00 PM
john melton's Avatar
Default oil in coolant on 97 5.9 cummins
hey yall,
im a backyard shade tree mechanic with a 97 dodge with 220,ooo miles on a 5.9 cummins. the old goat has been good but she has a LOT of oil in the coolant. I pulled the oil cooler and tested in and found no leaks. The truck has never run hot and is all stock. I bought and replaced the cooler with a new one "before testing it" an d still got oil in the coolant. now im 5oo in the hold with still the same problem. any suggestions where to go next?
Old Dec 14, 2010 | 06:32 PM
12vcummins96's Avatar
head gasket
Old Dec 14, 2010 | 07:27 PM
I was afraid of that. Is the oil under pressure in the head? I had always thought it was pumped up to it and then it drain back down to the pan? Is ther anyway to check it"the head" before removal?
Thanks
Old Dec 14, 2010 | 07:35 PM
blowin smoke 1's Avatar
Its the head gasket mine blew two weeks ago.Look at the gasket when you take it off you can see where it was leaking.It is not to bad of a job good luck!
Old Dec 14, 2010 | 07:39 PM
94cummins12v's Avatar
head gasket for sure oil pressure overpowers water pressure
Old Dec 15, 2010 | 03:16 PM
CreeperSleeper's Avatar
Thanks
Yes, the oil is under pressure. That is how the oil gets to the top of the head to drain down...
Old Dec 15, 2010 | 08:16 PM
anybody need a slightly used "5 min" oil cooler for 1997 5.7 cummins?
Durtyd09
Nov 11, 2015 01:43 PM
stevenb86
Mar 8, 2015 10:02 AM
coors_man_2005
Dec 15, 2014 10:23 AM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Chevy/GMC Duramax 01-04 LB7
Nov 9, 2014 04:49 PM
