transmission upgrades
Old Dec 14, 2010 | 01:30 PM
cumminsp12v's Avatar
Default transmission upgrades
im was wondering what the most efficiant way (cheap) is to do a minor build on the transmission? cash is low and i want to know what some simple mods are that will be worth the money. also would a shift kit help any? thanks
Old Dec 15, 2010 | 09:46 PM
sstockton's Avatar
Really a converter, valve body and clutches should all be done at the same time or you are just putting a band-aide on it for very short term.
Sean
Old Dec 19, 2010 | 03:00 AM
leveled03's Avatar
Sean
new stock clutches? or after market HD ones? and what if the stock ones dont look bad?
thanks
Old Dec 19, 2010 | 07:15 PM
manny31's Avatar
I used trans-go shift kit and got a convertor built by a local company has worked very well over 40k of hard use.
Old Dec 27, 2010 | 10:25 AM
cumminspwr11's Avatar
you can get black hi engery clutches for pretty cheap or red altos for not too much more, i would also look at putting in different selector plates that allow you to put in one extra clutch and steel into each clutch pack,
if you are tight on money i got the entire rebuild kit from dacco with the black high engery clutches for $150ish and thats all new seals and everything, then get a single dish tc for $300-400 and put a transgo shift kit in there, i believe they are around $50
Old Dec 30, 2010 | 05:56 PM
ok thanks $600ish isnt bad for a mild built trans
any idea what kinda horsepower rating this set up would be good to? just an estimant
Last edited by cumminsp12v; Dec 30, 2010 at 05:56 PM. Reason: Automerged Doublepost
Old Jan 5, 2011 | 08:35 AM
single disk tc is good for about 850lbs and maybe 350-400hp, the rest of the parts would hold up fine to alot more power, the hp isnt what does the tc in, its the torque that destroys them and they are the biggest weak link in the stock trannys
Old Jan 5, 2011 | 08:48 PM
ok thank you
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
hulse09
Feb 3, 2015 08:18 AM
Trevlar11
Dec 11, 2014 03:30 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
